03-20-2016 14:13
03-20-2016 14:13
The blaze advertises a 5 day battery. When I orginially got it, it would last 2-3, which I thought was no big deal because I played with it alot. However, the last week or so my battery seems to be draining. Yesterday I let it fully charged and have made it a point to not play with it excessively since it was charged. It has been about 20 hours and I have < 1/4th battery remaining. Is there something going on in the background that is just draining my battery? I didnt pay this much to charge my watch daily and I can't find why the battery won't last.
07-17-2017 07:48
07-17-2017 07:48
After getting a replacement fitbit Blaze back in April, the new one is now barely holding a charge for 1 day. I don't even have bluetooth notifications turned on, so I'm not using some of the advertised features. What a waste! I've used fitbit products for over 6 years now. It's time for me to explore other options.
07-17-2017 07:54
07-17-2017 07:54
Best Answer07-18-2017 08:16
07-18-2017 08:16
I went back to Best Buy and traded my blaze in for a new one. I told them that it wasn't holding a charge for more than a few hours and they exchanged it just fine. My new one is holding a charge perfectly. It has only used 1/4 of the battery and i took it off the charger almost two days ago. I was reading in some thread that fit bit just sends you the fit bit part and not an entirely new watch. Someone was told too that they send you ones that were sent back by other customers. So if you are exchanging through fitbit themselves, I don't think you guys are receiving brand new watches which is why you are having the same issues. Someone else sends back their watch with a defunct battery and they just send that one out to someone else who is exchanging it. I suggest you exchange it from the actual place you purchased them from to insure you are getting a brand new watch.
Best Answer07-21-2017 09:14
07-21-2017 09:14
I bought my Blaze in May 2016. At first battery life was 5 days. Over time it did start lasting fewer days. The Last few weeks I have to charge it ever day. I have tried turning off all of the sync and notifications, and it still only lasts a day. I had a Charge HR before the blaze and it top over time didn't hold battery charge as long as it should. I'm glad it mad it over a year before it started to annoy me, but for as much as they cost, the battery should perform better longer.
Best Answer07-22-2017 03:28
07-22-2017 03:28
Best Answer07-22-2017 09:24
07-22-2017 09:24
Fitbit sent me a new Blaze device(not the charger or band)..since it was not holding a charge and still under warranty. I have had it for about a week and the charge is holding. I'll give an update after a month since I'm hearing other users are still getting a bad charge. Obviously, this is a common problem and based on all of our community response issues I think they need to be recalled until this charge problems is fixed. It only gives the Apple Watch more business.
Best Answer07-22-2017 11:17
07-22-2017 11:17
Best Answer07-24-2017 11:53
07-24-2017 11:53
I have the same problem I'm on my 4th Blaze since June and there has been nothing but problems. Either battery not holding a charge, or not being able to charge or just not working Black screen. I'm returning it for the 5th time and hopefully I will be able to get my money back and buy a different fitness tracker.
Best Answer07-24-2017 14:03
07-24-2017 14:03
Best Answer07-26-2017 04:06
07-26-2017 04:06
Hello all, I hope you are doing fine. ![]()
If your trackers are not holding a charge, I recommend following the instructions provided in this post. After these steps test your devices.
Let me know the outcome. ![]()
Best Answer07-31-2017 18:38
07-31-2017 18:38
I'm having this same issue as well- just started up a few nights ago. My Blaze never had issues holding a charge for 4-5 days and now suddenly it doesn't even last 1 day. I'm charging the unit to "full" while sleeping but the battery is draining much quicker than before. The unit was purchased in Feb 2017. 😞
Best Answer08-01-2017 03:10
08-01-2017 03:10
Best Answer08-01-2017 04:40
08-01-2017 04:40
Best Answer08-01-2017 04:51
08-01-2017 04:51
Best Answer08-04-2017 13:07
08-04-2017 13:07
Mine all of a sudden started doing this about a month ago. I switched out my cracked one with my replacement and i don't use the music or notification part. It (new one) was fully charged as of Thursday am and I synced it, no workout or major activity and it was halfway this am and now I just got the notification of low battery. I even thought it maybe the the display or the syncing. So I changed the display yesterday and my sync is not set to auto...so I don't know.
Best Answer08-04-2017 14:32
08-04-2017 14:32
Best Answer08-04-2017 18:26
08-04-2017 18:26
This has been my experience so far. Fitbit asked for me to charge the tracker to full and then syn 5-6 times throughout the day for data tracking.
They were able to see that the battery was draining at a high rate and are giving me a replacement. 🙂
Best Answer08-06-2017 15:05
08-06-2017 15:05
I have only had my blaze for about three weeks and the charge is already starting to only last 2/3 days down from the 4/5 days it lasted for the first couple of weeks!
Best Answer08-09-2017 14:28 - edited 08-10-2017 07:57
Today my Blaze only remained charged for 6 hours, it is steadily getting worse and worse although I have not changed how I use it or care for it. I don't use the messaging on it, I don't use music control, etc. This is beyond ridiculous. Here is Fitbit's suggestions:
The thing that really bothers me most about their support is that they are suggesting that we stop using features that we once were able to use and the battery life was fine. It's also amusing to me that on page 1 of this thread, they marked this issue as solved. Turning off features that customers thought would work when purchasing this product is NOT a solution. It's a lazy man's workaround at best! I am going to try the Bestbuy return route to see if I have any better luck, beyond that, I will be done with Fitbit. Their competitors products do a lot more and if I'm going to have to charge it everyday anyway, I may as well make the switch.
Best Answer08-09-2017 23:31
08-09-2017 23:31
Please help my Blaze will not hold its charge for longer than 24 hours.
