Best AnswerIf it tries to sync then the Fotbit should already be set up, but the Blaze ahowing the fitbit.com/setup says it is not.
My thought would go to your device page and add the Blaze to your account again.
When setting it up, it needs to find the Blaze, display a code on the app and Blaze, you will need to confirm.
Let us know what step out fails at.
@AshleyGM Just out of curiousity - does the Blaze already show up under your Bluetooth on the phone? If so, chose forget this device and try again. (If you haven't already)
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Hello @AshleyGM, @Rich_Laue, @ladynay, @SunsetRunner and @Kmransom123 it's great to have you here 🙂 @AshleyGM where you able to set up your Blaze? since you already troubleshooted your Blaze and if you are still unable to pair it, I would recommend to reach out to customer support so they can assist you.
Let me know how it goes! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer@ladynay i needed to search back to see what wasn't working, and what phone. Iphone 6
I'll assume you have tried the normal hard reset, the shutdown through the Blaze settings screen, turned off then on the phone, went into the phones BT settings and told it to forget the Blaze. Now open the app and try to sync.
If none of the above doesnt work, try adding the Blaze as a replacement device to your account.
You also stated the computer doesn't work, if it is a Win10 have you tried syncing through the cable? Plug it in, wait for the drivers to download, then the app should sync.
Unless your computer supports BT Low Energy you need enable BT classic on your Blaze for your computer to see it.
Best AnswerBut the Blaze needs BTLE to sync, amd this would require a Fitbit dongle, or a pc with BTLE and the Win10 app. BT classic is unable to sync, and is used only for music control.
