03-17-2016 20:05
03-17-2016 20:05
03-30-2016 10:40 - edited 03-30-2016 10:41
To get mine to work, I had to first sync to my computer with the charger and update the firmware on the Blaze. Then I was able to sync to my Samsung Note 4 just fine.
It took several times to get it to work with the computer, as it didn't like 1 of the USB ports. Would only work with a USB port on the back of the tower.
03-31-2016 02:31
03-31-2016 02:31
Rich_Laue I have seen some third party "Fitbit" dongles. Do they work ok or are they just junk. I was just wondering. I have a friend at work that wants to try one and I told them I wasn't sure if they were any good or not.
03-31-2016 07:22
03-31-2016 07:22
04-02-2016 06:17
04-02-2016 06:17
Hello @AshleyGM, @ladynay, @Rich_Laue, @KiloLima64 and @cinblog1965. It's great to have you here 🙂 @AshleyGM Did you receive your new phone? Where you able to set up your Blaze? @ladynay where you able to set up your Blaze? Did you try using a computer to set up the tracker? @cinblog1965 thanks for sharing your experience, I'm glad to know your Blaze is syncing properly with your Samsung Note 4! 🙂 @KiloLima64 as @Rich_Laue mentioned I haven't seen any 3rd party Dongles. If you purchase your Blaze and you need a Dongle please contact support so they can assist you. Also you can purchase a Fitbit Dongle at the Fitbit Store.
I'll be around if you have any questions! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
04-02-2016 06:23
04-02-2016 06:23
04-02-2016 15:32
04-02-2016 15:32
04-02-2016 16:17
04-02-2016 16:17
04-02-2016 17:53
04-02-2016 17:53
04-02-2016 18:08
04-02-2016 18:08
04-04-2016 04:47
04-04-2016 04:47
@AshleyGM I'm glad to hear your Blaze is syncing properly with your new phone! 🙂 @ladynay I would recommend to contact customer support so they can provide you a one on one troubleshooting experience. @cinblog1965 thanks for sharing your experience! 🙂
04-04-2016 07:46
04-04-2016 07:46
04-05-2016 04:40
04-05-2016 04:40
Hello @ladynay did you review on your tracker if notifications are turned on? I would recommend to review this post for more information about music control and this post for notifications on the Blaze.
Happy stepping! 🙂
04-05-2016 09:02
04-05-2016 09:02
04-07-2016 04:25
04-07-2016 04:25
Hello @ladynay 🙂 I would suggest to contact customer support, they can review your tracker's back-end information and provide you a personalized troubleshoot. Let them know with details the performed troubleshoot to save some time 🙂
Let me know how it goes!
04-28-2016 03:31
04-28-2016 03:31
Seems I have the same frustrating problem as millions of other people that have just purchased a Fitbit Blaze. Running a Samsung S4 on the lollipop system and when i scan in my Bluetooth the Blaze is viewable to sync but rejects it everytime i attempt to Sync. I tried syncing from the fitbit app but it just keeps telling me turn on Bluetooth ( yes Bluetooth is on) and make sure the Blaze is turned on. I am assuming my screen isnt showing a charge battery or any screen as it hasnt been sycned yet and just keeps flashing www.setupfitbit. I Also have my location turned on as mentioned on some of the help pages. I evan tried downloading the app on my computer but then it asks for a Dongle..the Blaze doesnt come with a dongle???
04-28-2016 04:34
04-28-2016 04:34
Hello @Katayesha welcome to the Fitbit Community! I would recommend to troubleshoot as instructed here. If you need the steps to restart your tracker click here.
Let me know if this helps! 🙂
05-03-2016 10:36
05-03-2016 10:36
After a fustrating couple of days Ive sorted out my sync problem with my new Blase. I switched the wifi off and started the sync using the app (HTC oneM8) but kept the phone screen live by keeping my finger moving on the screen. The phone and blase have updated and now working correctly. Basicly dont let your phone go to screen saver
05-13-2016 05:27 - edited 05-13-2016 05:29
Hello @bubblehead, welcome to the Fitbit Community! It's great to have you here. Thanks for taking the time to share your experience with syncing using your HTC One M8.
Hope to see you around more often! 🙂
05-21-2016 21:18
05-21-2016 21:18
I have had this problem on and off with notifications all of a sudden not being sent from my Galaxy 5S phone. What seems to work is updating fitbit software in Google Play store, restarting my phone which allowed it to sync again. Notifications are working now.
05-23-2016 05:48
05-23-2016 05:48
Hello @Beaglelover It's great to see you around. Thanks for sharing your troubleshoot. 🙂 I'm glad to know that your Galaxy S5 and the Blaze are working properly.
