I tried to change my clock face and now I get only an error message and the screen is locked to this message. "Clock Error" go to the Fitbit mobile app and choose another clock face. Did that on PC and phone. Nothing worked. Help!!
It's great to have you here @Sooz67! I would like you to restart your tracker and try the syncing troubleshoot.
Additionally, after your Blaze has been successfully synced try the procedure posted above by @wmchapman.
Hope this helps.
Change to a "different" clock face, force sync, then change back to the one you want and force sync.
This should clear it up @Sooz67
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
Hope this helps.
Best AnswerThank you! Solved the tracking issue but my clock face is still gone. Only the error message us displayed. Grrr
Thanks for the details provided @Sooz67! I've shared your post with Customer Support, they should reply to you within the following days.
Hope this helps!
