02-22-2016 09:42 - edited 02-22-2016 10:26
Hey all!
I've been seeing a ton of great conversation about Connected GPS- the technology that will allow you to see your maps, as well as pace/distance using your phone's GPS. Ahead of launch of the device, I'd like to provide a bit more information about Connected GPS in comparison to our built-in GPS technology (found in Surge) or our existing GPS functionality in relation to other devices! The following is an in-depth look at Connected GPS, and and opening of the floor for questions! Are you ready? Let's do it!
Connected GPS is a new part of the Fitbit ecosystem! Using Connected GPS, Blaze connects with your phone's native GPS capabilities to plot routes and activity stats screen as the pace and duration.
The necessary components for initiating a Connected GPS exercise are:
To initiate a Connected GPS exercise, open the appropriate exercise (exercises that offer GPS connectivity on the Blaze will have a gear icon on the tile). Once you select the exercise type, you'll see that your Blaze will begin to look for your phone's GPS services. Once the device establishes a connection, you'll be notified that you're ready to go. You can always bypass the connection if you'd like, much like on Surge.
GPS is built-in on the Fitbit Surge, meaning that you could initiate a GPS activity without your phone in proximity. The MobileRun process works a bit differently; you'll have to open the Fitbit app and select Track Exercise > Stopwatch Icon > Start.
Phone Not Found: Users may see the following error state if their tracker is unable to connect to their phone. If this happens, please ensure the following: phone is within range, your app is open, phone is charged up, Bluetooth enabled and bonded, and Internet connection is present.
Check Fitbit App: If you come across this error, there may be a bit of action required. Please ensure that your app is open, you are logged into your account, and that location services are enabled.
Location services are required for Connected GPS to function properly. Please ensure that location services are enables, and set to "Always" if applicable.
Permissions are requested upon setup of the tracker. Users who intend to use the Connected GPS feature should accept the permission requests. If you switch phones during the life of your Blaze, you'll be prompted to run through all of these permission requests again before being able to successfully use Connected GPS.
04-07-2016 10:05
04-07-2016 10:05
Best Answer04-07-2016 10:11
04-07-2016 10:11
Best Answer04-07-2016 11:44
04-07-2016 11:44
Best Answer04-07-2016 12:00
04-07-2016 12:00
Best Answer04-07-2016 12:02
04-07-2016 12:02
Best Answer04-07-2016 14:10
04-07-2016 14:10
Best Answer04-11-2016 21:36
04-11-2016 21:36
Followed instruction to turned on GPS of my phone. But my Blaze connected GPS is not working with HTC M+ (M9pw), the Blaze shows Check Fitbit app always.
HTC m9+ Android is 5.0.2
Blaze 17.8.104.1
By the way, the notification is working well for coming call and text message (but not supporting traditional Chinese).
@EmersonFitbit wrote:Hey all!
- What is Connected GPS?
- How do I use Connected GPS?
- Your charged tracker
- Your compatible Mobile device with GPS capabilities
- The Fitbit App
- How is this different than Surge? MobileRun?
- What errors might I run into?
- Location Services and Permissions:
Best Answer04-12-2016 02:54
04-12-2016 02:54
@SunsetRunner, I'm not sure the reason for the 6 paragraph quote, it really just distracts from your question. Is the App running at least in the background, and the phone's location services set for GPS?
Best Answer04-12-2016 03:53
04-12-2016 03:53
Good morning! The reason add the quote is the paragraph "What errors might I run into?", I don't know what in Fitbit app needs check?
The phone network is connected, GPS and BT are on, Fitbit app is running on the phone screen and my Blaze is synchronized with Fitbit app.
Best Answer04-20-2016 20:48
04-20-2016 20:48
I am wondering if you can see this map while you are walking or cycling or whatever activity? I can only see this map after I have clicked on the Finish Line flag in the exercise screen. I would love to be able to see the map and my path while I Am walking.
Thank you
Best Answer04-21-2016 23:16
04-21-2016 23:16
As stated in previous posts on this thread. No map is shown on the Blaze while you are walking, and the app since it is not tracking there will not be a map there also.
Best Answer04-25-2016 15:45
04-25-2016 15:45
Best Answer05-01-2016 20:00
05-01-2016 20:00
I am currently using Strava as my GPS app along with the Bike exercise app on my Blaze. It has been right on the money with the distances. My phone is a Galaxy S6. Only issue I have now is the dashboard is showing 2 different bike rides starting at the same time with 2 different calorie counts.
Best Answer05-02-2016 23:51
05-02-2016 23:51
Best Answer05-03-2016 00:37
05-03-2016 00:37
05-03-2016 01:45
05-03-2016 01:45
@Julia_G thats awesome! Thanks for the input. Just went ahead an ordered a Blaze for myself 🙂
Best Answer05-03-2016 14:14
05-03-2016 14:14
I found the location accuracy I have set for the phone has a profound effect on the accuracy of the connected GPS.
Best Answer05-03-2016 14:38 - edited 05-03-2016 20:41
@Rich_Laue I have been testing this and my conclusion is the app-Balze connection is not using the GPS data. You can test this yourself by setting the phone to GPS only and you will find you get one red bar on the connected screen and the Blaze will not record a mapped track, only steps. Setting the location to No GPS (Wi-fi-cellnet only) will give you a connection and record an incorrect distance, Setting the phone to high accurancy will also get you a good connection and will also record an incorrect distance. Interestingly the phone location symbol in the status bar is activated when you start the Blaze exercise but the GPS seems to be not being used.
You can also manually start the GPS with another app to make sure it is started but this makes no difference to the error.
05-03-2016 19:53
05-03-2016 19:53
Best Answer05-03-2016 20:43
05-03-2016 20:43
On Android we have the option to set accuracy off,
Wi-Fi, and Cell service only, this also works with wifi and cellular network turned off.
Wi-Fi, Cell service, and GPS
GPS only, many apps complain with this seeing
Each setting affects the way the phone determined its location.
