12-29-2016 03:58
12-29-2016 03:58
My heart Rate monitor simply stopped working, I cleaned it and changed it to the other arm, still no results...
07-17-2019 17:14
07-17-2019 17:14
I tried everything. It still just displays 2 dashes instead of my hr
Best Answer07-17-2019 17:15
07-17-2019 17:15
I tried everything, it still just shows 2 dashes instead of my hr
Best Answer07-17-2019 17:16
07-17-2019 17:16
Didn't work
Best Answer07-17-2019 19:28
07-17-2019 19:28
Here's what's going on with mine. It wasn't showing the HR, only two dashes. I unlinked the device from my account, uninstalled the app, and then I put the Blaze into the charger while it was plugged in. I then did a restart using the left and lower-right buttons for 10 seconds. After that, it showed the HR again - UNTIL, I again linked it to my app!, Then, the HR turned into two dashes again. WTH??
Best Answer07-17-2019 20:39
07-17-2019 20:39
Best Answer07-17-2019 23:04
07-17-2019 23:04
Best Answer07-17-2019 23:06
07-17-2019 23:06
Best Answer07-18-2019 05:56 - edited 07-18-2019 05:59
Yeah, this is more of a fitbit employee problem.
Best Answer07-19-2019 06:54
07-19-2019 06:54
Hello.
I am new to the Fitbit world. My wife got a new Tracker and gave me hers. She said it worked but was having trouble with the HR as it was being intermittent and not recording her sleep.
I have been wearing for the past day and a half and have not had the HR work at all. I have tried the 2-button rest, the shutdown, turning HR off then syncing, then turning HR back on and re-syncing. It seems to be a similar issue as others. Oh, and the two green lights work.
I did speak with two people at customer service, 1 the first night who helped me with clearing out my wife's data. It didn't really work because all of her data is recorded on my first day since it didn't truly clear her info properly when synced to a new account. The other was yesterday who got the HR to go from 2 "--" to "70" and we thought it was fixed. That being said, the Blaze still says 70 but doesn't record any other HR or log it into the app.
Best Answer07-19-2019 08:57
07-19-2019 08:57
Best Answer07-19-2019 10:27
07-19-2019 10:27
Best Answer07-19-2019 19:13
07-19-2019 19:13
I've done every form and combination of reset /unpair / uninstall / turn on/off possible.
Best Answer07-19-2019 23:20
07-19-2019 23:20
Best Answer07-20-2019 07:07
07-20-2019 07:07
Yes. I did that. And all other forms of reset.
07-20-2019 09:29
07-20-2019 09:29
I will let it drain out and try again. May take a couple days. Will keep you posted.
Best Answer07-20-2019 12:06
07-20-2019 12:06
Best Answer09-16-2019 16:15
09-16-2019 16:15
I'm having a similar issue with my heart rate monitor on my Blaze:
In addition to to the HR monitor issue I also have to charge my battery daily; when I usually could get 5 days from a single charge.
Any suggestions for a fix?
Best Answer09-16-2019 17:02
09-16-2019 17:02
09-16-2019 17:04 - edited 09-16-2019 17:05
Welcome to the Fitbit Community, @Mvnesbitt. It's nice to see you around @Chidder.
@Mvnesbitt Thank you for joining the thread and sharing the details of the issue with the heart rate monitor on your Fitbit Blaze. I would like to confirm if you've tried the troubleshooting steps from this help article: Why don't I see my heart rate on my Fitbit device?
Regarding the issue with battery, please double check our charging instructions and tips for preventing battery drain since battery use is affected by various factors and settings.
@Chidder thank you for your helpful tips!
Please keep me posted.
Best Answer09-16-2019 17:51 - last edited on 09-16-2019 18:11 by LiliyaFitbit
Yes I tried the troubleshooting solutions described. Ensured the HR was
turned on in the app and device, as well as restarting Blaze...I still only
have one flashing green light on that back of my Blaze.
