I have done all the recommendations with Fitbit customer support. They are sending me a new watch.
Best AnswerI agree with you. I am in the same boat. I really enjoyed my Blaze for the year that it worked. However seeing many in the same predicament makes me want to abandon the brand. I understand it would be costly for Fitbit to replace out of warranty products but with so many users having the same issue and not trying to make it right is not a good look by Fitbit.
My heart rate monitor just stoppped working tried all the reboots ect nothing also battery is lasting a day! Fit bit got back to me once! To say what to try! It started to work by its self again then went of again. I've emailed several times and have heard nothing back from fit bit. Not impressed at all.
Mine is officially not reading anymore either. Green light is on, app is set to HR Monitor as on, eyc
Mine had been sporadic on/off, but after having it work for almost an entire day it hasn't been reading anything.
As much as I loved the blaze, 2 units in a little over a year is kind of ridiculous
25% off discount on select products which brings it down to retail price!
Yeah...no thanks. I can get a replacement Blaze for $159...that's literally walk into any store price
The Blaze was a carry over from the Pebble buyout, I have no interest in it.
I was fortunate to buy my blaze on sale and had it replaced within 3 months due to it not powering on.
To say I'm enthusiastic about dropping more money on a replacement product then I did on my original investment is an understatement. I'll cut my losses, but definitely disappointed.
I just used the reset instructions
provided by Ferdinandfitbit
worked perfect to reset my heart rate monitor.
thanks!!!👍👍
Best AnswerHi I have just bought a Fitbit blaze but the heart beat monitor doesn’t seem to be working correctly should it show your heartbeat even when you are not exercising? I had read some previous comments and the lights are green, I have checked the settings and it’s set to auto, I have also tried setting it to on, when I did the shutdown and reset the monitor came on for a little while showing 70 , but. When I checked again just shows ❤️- - is it faulty ?
Best AnswerHi!
I have same problem but my green light is blinking and my heart tracker is on too.
However in the screen, the heart rate reading is just "--"
can you help me?
Thanks a million,
Lucia
Best AnswerSame with mine 😔😔
