12-29-2016 03:58
12-29-2016 03:58
My heart Rate monitor simply stopped working, I cleaned it and changed it to the other arm, still no results...
10-12-2017 17:42
10-12-2017 17:42
10-13-2017 10:03
10-13-2017 10:03
I have tried holding all 3 buttons but HR still doesn't work. Any other suggestions please?
10-13-2017 16:21
10-13-2017 16:21
10-14-2017 01:21
10-14-2017 01:21
Thanks...tried that...still not working. Any other suggestions?
10-14-2017 04:59
10-14-2017 04:59
10-16-2017 07:06
10-16-2017 07:06
10-21-2017 13:22
10-21-2017 13:22
What's the solution? I'm viewing on a mobile device and don't see anything?
11-17-2017 03:52
11-17-2017 03:52
thank you so much - I tried this and got the heart rate monitor working again - many thanks.
11-17-2017 04:16
11-17-2017 04:16
11-21-2017 13:06
11-21-2017 13:06
This was an easy fix...mine was set off too (?). Glad it was an easy fix!! Thank you for posting.
11-29-2017 18:44
11-29-2017 18:44
@Mspicer01. Thanks for your suggestion. It works.
12-02-2017 16:49
12-02-2017 16:49
How long does the warranty last? My Fitbit Blaze is 2 years old and the HR Monitor has just stopped working properly. I have tried all the reset fixes on here and none of them have worked? Is it time to buy a new one?
01-21-2018 07:42
01-21-2018 07:42
Hi,just found your post and tried it on my Blaze. Worked first time. Thanks a million or at least $200 because I was pitching my Blaze. 👍
01-21-2018 08:33
01-21-2018 08:33
01-22-2018 05:18
01-22-2018 05:18
02-07-2018 09:22
02-07-2018 09:22
I was having the same issue and this helped me out! Thanks!
02-07-2018 13:14
02-07-2018 13:14
My blaze is a little over a year and my heart rate monitor stopped working as well. I did all of the troubleshooting and spoke to agent on a live chat. Unfortunately the warranty is for 1 year only and I was only offered 25%off my next purchase. I felt ok with that until I started reading these forum posts and discovered that a majority of fitbit users are on their 2nd or third one after a year or in some cases less than a year. Which makes me leery of buying a second one only to replace it in a years time .... I feel torn I enjoyed my fitbit and have so many bands for it but I don't want to shell out $150+ bucks every year either....
02-08-2018 05:11
02-08-2018 05:11
Mine stopped working also. I have done all the resets recommended. I had it set to auto and have now changed it to ON. No help. My warranty has just expired of course. Not only have i lost the heart rate monitor but that means it no longer measures sleep. Need to find a better reliable brand.
02-08-2018 09:13
02-08-2018 09:13
Turns out i have 5 more days of warranty left. i used chat this morning and still no fix. they will contact me via email using the next level of support..
02-09-2018 06:11
02-09-2018 06:11
Hi I am also having issues with the heart rate monitor on my blaze. Green lights are blinking, I have rebooted the device, I have toggled the setting from Auto, to ON, to OFF, to Auto and nothing seems to bring it back any other thoughts?
