12-29-2016 03:58
12-29-2016 03:58
My heart Rate monitor simply stopped working, I cleaned it and changed it to the other arm, still no results...
05-09-2018 15:42
05-09-2018 15:42
Will that clean the sweat out of it?
05-09-2018 18:56
05-09-2018 18:56
I did try that and no luck. However I did start reading again when I went into settings and turn it on instead of auto. No my worry is the battery life.
05-09-2018 18:58
05-09-2018 18:58
I didn’t have an issue till I started working harder. I think that might be my problem but customer service gave me more links and the same advice. I think it will slowly die 😕
05-09-2018 18:59
05-09-2018 18:59
Thanks for the suggestion but when this dies if it does, I’m going to Apple.
05-15-2018 18:23
05-15-2018 18:23
Yep this worked for me. I'm not exactly sure how or why it got turned off but it was off. Its working now. Thanks for the help.
05-15-2018 19:29
05-15-2018 19:29
So say they are going to replace it! I was shy of a few days of begin over my warranty. My problem is solved but I feel like this watch should last longer than a year : / idk just my thought I spent over 250.00 for it.
05-15-2018 20:20
05-15-2018 20:20
05-17-2018
09:42
08:40
05-17-2018
09:42
08:40
Hey guys, hope you all are doing fine.
I appreciate all the efforts in trying to fix the heart rate sensor issue you are experiencing, it's great to hear that for some of you this has been resolved and have received a replacement or your Blaze started working again.
For the ones that still have this issue, have you tried to restart your trackers? If you haven't, I recommend restarting them by doing the following:
If you have already tried this without result, let me know.
05-26-2018 08:56
05-26-2018 08:56
Hi all,
Can I add another HR problem to this pile?
Progressively worsening over the past couple of months, now at a point of no Auto HR sensing. Functions fine when sensor is 'on', but battery drains after 1 day - so its not workable.
When set to auto, I get the both lights flashing every second or so, not the constant flicker that is normal.
Really disappointed as I am a big fan of the HR function.
I've tried:
Change settings via app and watch.
Reset with two button method.
Switch off from watch.
Re-pair with phone.
Anything else to try?
Unfortunately I think it will be out of warranty. I think purchased in mid-late 2016?
05-26-2018 09:29
05-26-2018 09:29
Heart rate sensor board got wet. From your description it looks like U1, a dual mux switch, has failed. It is very close to the sensor window and is vulnerable to sweat exposure when the HR sensor window cracks and fails.
Analog Devices ADG772
The part is available at Digikey Electronics. It is a difficult part to replace however.
Another much easier option is to buy a FitBit with a broken screen and swap rear covers.
05-26-2018 11:43
05-26-2018 11:43
05-28-2018 18:46
05-28-2018 18:46
resetting it worked .... thx
05-28-2018 22:52
05-28-2018 22:52
This is the exact same as my Blaze. The HR is frozen at 70. It did not get wet. I have reset it numerous times. I have cleaned the sensor. I have let the battery run down completely for three days hoping it would clear the cache? I then let it charge fully and reset it. Still it does not track. I have turned the Blaze off then on again When the heart rate is on it is frozen at 70. The sensor are constantly blinking, but still no heart rate.
07-03-2018 06:49
07-03-2018 06:49
This was a great help and worked like a charm! Thanks!
07-03-2018 08:33
07-03-2018 08:33
Hello,
I'm also having trouble with my HR monitor. Currently, I can't get the lights to turn on no matter what I do. I've tried re-setting with the buttons and with the app, and I've tried switching the HR setting from Auto to On. My watch is running the latest OS. I've re-set the watch and synced more times than I can count.I seem to get intermittent lights. A flash here and there, sometimes a few hours worth, sometimes sleep tracking but other times not.
I wanted to remove the device from my account to re-install, but I'm scared to because there is no longer a 'pair' option under settings.
Suggestions?
07-03-2018 20:58
07-03-2018 20:58
07-12-2018 00:18
07-12-2018 00:18
Hi, mr HR stopped working a few days ago, both lights not on. Tried turning heart rate on and off on the app and watch and also reset and turned the watch off and on again but still not working...
07-15-2018 07:23
07-15-2018 07:23
Thank you so much. It worked. I pressed left and right bottom one and it started working
07-23-2018 11:10
07-23-2018 11:10
Hi Alejandra
I am having problems with the HR function on my Fitbit Blaze, I suspect it got too wet. I have tried doing resets and ensured that the HR function in the app is set to on or auto.
I don't see the green lights on the back being lit up.
What are the next steps in getting the HR function working?
Thanks
Steven
07-23-2018 19:38
07-23-2018 19:38
