@Kimisdashhhhh Check out the post I made in this thread here. Sounds similar to what you're experiencing.
@mardon41 wrote:I am having the same problem with total steps, I was at around 77 K, dropped to 66, today is at 50. What is going on ? Please help
Maria
Are you referencing your true total steps, or are you referring to your rolling 7-day total; your total steps will never go down, your rolling total will drop after midnight every day as the 7th most previous day's activity drops off.
Cannot insert the screenshot, sorry, but this is what I am talking about
. Dashboard/Friends, shows total lifetime steps.
Tks
Maria
@mardon41 wrote:Cannot insert the screenshot, sorry, but this is what I am talking about
Tks
Maria
You might want to edit your post to remove the three miles of white space 🙂
Anyway, on Dashboard/Friends, it shows the last 7 days total, not lifetime.
Best AnswerSorry for the "long" previous reply, and the oversight.
Where do I go or what do I do to show lifetime steps ?
Thanks soooooo much for your prompt replies.
Maria C
Best Answer@mardon41, if you're looking at this screen (phone):
Or if you're looking at this screen (Fitbit.com Dashboard):
Then all you're looking at are your steps for the six previous days plus whatever you've done today. To look at your lifetime steps you should look at this tile on the Dashboard:
