02-25-2016 08:35
02-25-2016 08:35
has anyone got notifications working with blackberrys Passport and Blaze.. i got it to sync and music volume control works .. but notifications don't seem to be forwarded to my Blaze ... any help would be greatly appriciated .. pat
02-25-2016 10:31
02-25-2016 10:31
Hey all! Blackberry phones aren't on the supported devices list, so we wouldn't expect full functionality with those devices.
Thanks for your feedback, however. We're always looking to expand our ecosystem, especially with compatibility.
02-25-2016 08:51
02-25-2016 08:51
how did you get it to work with the passport? my fitbit app keeps saying update software
02-25-2016
08:55
11:07
FerdinandFitbit
02-25-2016
08:55
11:07
FerdinandFitbit
I got that also ... however I deleted the old version I had for my charge HR and reinstalled a new one from the AMAZON Appstore . and then it just started working ... oat
Patrick G. Morassutti
Moderator edit: Personal information removed
02-25-2016
09:15
17:28
EdsonFitbit
02-25-2016
09:15
17:28
EdsonFitbit
Hello did you delete the amazon app from the passport or charge hour from the app?
02-25-2016 10:31
02-25-2016 10:31
02-25-2016
10:51
17:28
EdsonFitbit
02-25-2016
10:51
17:28
EdsonFitbit
Yet it is the same fitbit app and it works on the blackberry phone for a few years now. And a blackberry runs android apps.
Moderator edit: format
02-25-2016 10:54
02-25-2016 10:54
02-25-2016 10:55
02-25-2016 10:55
@Gshock Ah, thanks for the heads up! I hadn't know that. ![]()
11:48
17:29
EdsonFitbit
02-25-2016
11:48
17:29
EdsonFitbit
Never had an issue with the app until The Blaze!
02-25-2016 12:57
02-25-2016 12:57
02-25-2016
13:05
17:29
EdsonFitbit
02-25-2016
13:05
17:29
EdsonFitbit
The Blaze is not even on the Windows 10 app so the BB10 system is about as good as it gets. If that's all your phone does is unsecure apps. Or mobile device. I will stick with the Charge as it updates fine and has the updated files needed.
02-25-2016 13:44
02-25-2016 13:59
02-25-2016 13:59
I've heard from our Windows expert (@RickyFitbit) that uninstalling and reinstalling the Windows 10 app will add Blaze to the setup list.
02-25-2016
15:42
17:29
EdsonFitbit
02-25-2016
15:42
17:29
EdsonFitbit
So to the guy who installed the blaze on his passport what exactly did you do with the app when reinstalled. Did you go to replace charge or add device in the application?
02-25-2016 23:44 - edited 02-25-2016 23:47
Thanks @EmersonFitbit top tip, that did it.
02-26-2016 09:43
02-26-2016 09:43
Has anyone gotten their Blackberry to sync with their Blaze?
(1) What App did you use? The Amazon App or did you sideload an APK?
(2) What did you need to do with the Amazon App? Mine is asking me to "Update the Application to Continue," unfortunately, the last Amazon App Store update was in September of 2015.
I am using a Leap and Amazon Version 2.12.2
I do not want to return my Blaze, but there has been no support from FitBit, only that "Blackberries are not a compatable device and that they are endeavouring to expand their ecosystem," which is not helpful.
02-26-2016 10:08
02-26-2016 10:08
Currently Fitbit supports iOS, Android and Windows Phones.
There's no fitbit app for Blackberry Phones.
Best Answer02-26-2016 10:10
02-26-2016 10:10
02-26-2016 10:10
02-26-2016 10:10
Incorrect. Blackberries can run Android Apps which are downloaded from the Amazon App Store.
@SunsetRunner wrote:Currently Fitbit supports iOS, Android and Windows Phones.
02-26-2016 10:28
02-26-2016 10:28
