03-17-2017 04:44 - last edited on 09-09-2020 09:49 by MatthewFitbit
I charged my fitbit charge 2 this morning and when I took it off charge, the battery symbol has remained. I cannot get it to go back to tracking steps or anything else.
03-17-2017 05:22
03-17-2017 05:22
Try restarting it using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
It does no harm and can sort out all sorts of issues
03-19-2017 10:08
03-19-2017 10:08
@AngieMassey It's great to have you here! Did the restart that @SteveH suggested worked for your tracker? I also suggest you clean the contacts by using a toothpick or toothbrush then use cotton with rubbing alcohol (also use this on the charging cable), then try restarting your tracker. This will ensure that a good contact is being made and this will help with the restart and charging process.
Let me know how it goes!
12-17-2019 21:30
12-17-2019 21:30
I am facing the same issue. Fitbit Chare2is stuck at the charging symbol. Unable to restart the band. Tried to hold the butter for more than 30 secs but no luck. Please suggest, what can be done
01-16-2020 21:12
01-16-2020 21:12
Hopefully you figured it out by now, but if you didn't, try holding the button while it is clipped into its charger.
Mine was also stuck and wouldn't reset if I held the button while it wasn't connected to the charger, but sure enough it did reset when I tried holding the button while it was connected. 🙂
06-20-2020 06:45
06-20-2020 06:45
My Fitbit charge 2 had a constant battery symbol also. I got a notice to update. After updating my Fitbit was restored to its normal operating parameters. Everything is working normal
06-26-2020 05:34
06-26-2020 05:34
Hi. I know this is an old thread but maybe somebody will see!
I have the same problem with the frozen battery on screen but none of the repair steps noted in this thread are working. Also, yesterday's steps carried over to today, did not restart at midnight. I did not change time zones.
I tried uninstall and reinstall of app, tried a restart of the fitbit several times (with pressing the button 3 times with that little vibration after each), tried holding that button for 10-12 seconds, tried cleaning the contacts. .
Nothing.
Yesterday afternoon the fitbit screen began flashing wildly and then by this morning it had worn itself out and the battery was dead. Now plugged back into the charger it appears half charged but again, battery icon stuck on screen. Might anyone know what to do at this point?
Fitbit customer service was helpful in the early days of my Fitbit use, seems almost impossible to get a real human and helpful info anymore. Maybe need to find another brand. Thanks.
06-26-2020 10:54
06-26-2020 10:54
06-26-2020 11:26
06-26-2020 11:26
Glad that worked for you Walt. The update didn't work for mine so it appears it's really kaput. A shame - too much plastic stuff has short lifespan and ends up in landfills or ocean.
08-09-2021 10:39
08-09-2021 10:39
Thank you so much!! It worked 👏🏼
08-12-2021 06:08
08-12-2021 06:08
Hello everyone. @Mrs.CA Welcome to the community forums!
It's great to hear that the instructions shared in this thread worked for you! I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
See you around.
