10-25-2017 06:14 - last edited on 09-09-2020 09:26 by MatthewFitbit
Had my charge2 for a week and it won’t track the deep sleep rem and the stages it to track when I’m sleeping. What do I do to fix it.
10-26-2017 07:50 - edited 10-26-2017 07:51
@Tdog2010 Welcome to the Fitbit Community! I hope you're doing well! Thank you for clarifying the issue by responding @JohnnyRow's question. Remember that you might not get sleep stages due to the following reasons:
You can also try restarting your tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Let me know how it goes!
10-25-2017 11:14 - last edited on 10-26-2017 07:50 by AlvaroFitbit
Is it not tracking your sleep at all, or just not breaking it into stages?
10-25-2017 11:38 - last edited on 10-26-2017 07:51 by AlvaroFitbit
It tracks the sleep but won’t track the stages of sleep like the guide says it dose.
10-29-2017 19:15
10-29-2017 19:15
Mine has just stopped recording sleep stages, as it did in September when there was a problem with the software. Anyone else noticing this problem?
10-29-2017 23:36
10-29-2017 23:36
I’ve had it 2 nights in a row as well.
10-30-2017 00:04
10-30-2017 00:04
yes mines been the same since the clocks changed
10-30-2017 12:47
10-30-2017 12:47
Yes! I just received mine a week ago - it tracked three nights worth of sleep and then nothing from last night. I've checked that everything is up to date (app, firmware, etc.). I slept for more than 3 hours and know that the tracker was tracking my heart rate due to the heart rate graph showing no missing data overnight. Is there a solution to this problem? This was the one feature I was most interested in and I'd love for it to work properly.
10-30-2017 20:34
10-30-2017 20:34
Mine has not shown sleep stages for around 4 or 5 nights now. I don't think I am doing anything differently to obstruct the Fitbit at night. Sure would like for it to show the sleep stages - it has become important to me to know how much deep sleep I get as well as REM Sleep and awake times. Hope there will be a fix on this soon!
10-31-2017 04:01
10-31-2017 04:01
Mine is not tracking sleep stages for 2 weeks after working almost flawlessly for several months. 😞
10-31-2017 04:31 - edited 10-31-2017 04:33
I am having, together with my wife, the same problem (no sleep stages tracked during the last few days).
I have followed your instructions but unfortunately the sleep stages are still not tracked.
Could you please advise how to proceed?
Thank you
10-31-2017 04:44
10-31-2017 04:44
Tried that still not tracking R.E.M. deep sleep etc !
10-31-2017 05:31
10-31-2017 05:31
its TD never split up sleep patterns properly on the iPad. Works fine on the girls phone. Every update it will work of the first read then stops. You can see the 5h33m tracked and the rest did not.
11-01-2017 15:30
11-01-2017 15:30
So confused why won’t it track the sleep correctly
11-02-2017 04:36
11-02-2017 04:36
The past 2 nights it hasn’t recorded properly. When I follow the instructions about putting it on the charger, and pressing the button for 10-12 seconds, the fitbit logo comes up with the number 225502. Is this the proper version? I’m a little irritated as my sleep these past few weeks has been poor; I haven’t changed the position of my fitbit, either, on my wrist.
Also, I took a screenshot of my app but I can’t figure out how to upload it.
11-02-2017 05:29
11-02-2017 05:29
Got in touch with Fitbit and it is working properly this morning.
11-02-2017 06:39
11-02-2017 06:39
My sleep tracker stopped working.
@JohnnyRow wrote:Is it not tracking your sleep at all, or just not breaking it into stages?
12-16-2017 08:39
12-16-2017 08:39
I reset my charger but it still is not tracking sleep
12-16-2017 12:37
12-16-2017 12:37
I got in touch with Fitbit and it was sorted out. Think it took three resets.
01-02-2018 07:09
01-02-2018 07:09
Just bought two Fitbit Charge 2 and one tracks sleep and the other doesn't. I've done everything that AlvaroFitbit suggests and nothing works. I think I'm just going to return this - there are cheaper alternatives - in fact, I bought my daughter a tracker for $10 and it works better than my fitbit. Also, it seems like this is a big problem reading all the complaints.
