Connected GPS Pace and Distance is Inaccurate
ANSWERED
Went on a run today with my Charge 2 on one wrist and Charge HR on my other wrist. Also had RunKeeper to measure my distance. I started my run with about the same number of steps on both FIT devices.
After the run, my Charge HR had almost 2K more steps than my Charge 2. In addition, my GPS map on FitBit matched my Runkeeper map which is about a 3.5 mile run BUT FitBit pegged the same route as 1.73 miles >.>
Why doesn't this device work as advertised? I really like the design and feel of Charge 2 but if it can't do its job accurately, all is for not and I will be shorting FIT as it appears to be a widespread issue (I have maps and photos if someone from FIT wants the data).
Moderator Edit: Edited thread title.
1 BEST ANSWER
Accepted Solutions
Hi everybody,
Please make sure that you've updated your Charge 2's firmware if you haven't already. The firmware update includes performance improvements for multisport mode and connected GPS.
Click here for instructions on how you can update your Charge 2's firmware if you havn't updated yet.
Derrick | Retired Moderator, Fitbit
569 REPLIES 569
Having the same problem with my Charge 2
Been walking on my lunch every day and found the charge 2 with GPS although the map is pretty much bang on the distance is less than half the actual distance (yesterday FitBit read 1.1 miles actual distance was 2.3 miles)
What i found very interesting is if i Auto upload the file to strava it shows the same distance as Fit bit. However by Download the GPX file and re-uploading the file the mileage gets corrected.
This clearly tells me that there is some form of calculation issue with FitBit.
FitBit support advised me this:
So we can continue checking about this inconvenience with the distance recorded on your activity. We'd like to try a few troubleshooting steps, first please restart your phone. And then, try restarting your Charge 2 following this procedure:
Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display. Your Charge 2 will begin charging.
Press and hold the button on your tracker for four seconds. When you see the Fitbit logo and the tracker vibrates, this means the tracker has restarted.
Unplug your tracker from the charging cable.
Did this yesterday and will be going for a walk again today, will see if this  helps
Strava
Daniel
I went for my usual walk today after the suggestions from Fitbit support but also with the following as well:
1. FitBit App was not running in background on Phone, App was primary open app with screen locked
2. Adjusted Stride length
3. Disabled Android's inbuilt battery saver entirely (despite already being disabled for FitBit App)
Now the results are good. The calculation was pretty much bang on what i would have expected, the difference being 0.3 miles shorter than yesterday however i did walk round my local shop less than yesterday AND the GPS picked up at a slightly different starting point from yesterday.
I would suggest giving this a go see if it helps
Strava
I am having the same issue with my Fitbit Charge 2. The connection with my phone's GPS is mapping the route accurately.
In one recent walk, the route is actually 3.5 miles.
  • Fitbit Charge 2 shows distance as 2.36 miles. (off 48%)
Steps should be around 7,000
  • Fitbit Charge 2 shows steps shows 5,761 (off 21%)
Why would the unit not take the results from the phone's GPS?
I am glad to see that, @Nsmithson - that is the same results I am seeing. I did several walks after mapping the route using my Jeep's trip meter, and each one of them was within less than 1% difference between the Charge 2 and the Jeep trip meter.
Ryan
I have a theory that i am waiting to be validated.
That theory is that when using the "Walk" option (and perhaps other activities) FitBit is not using GPS in order to determine the distance but is instead using the Stride length to determine the distance
I don't actually believe for Step based excersize that the GPS has any bearing on distance whatsoever and probably setting the stride length correctly will probably fix the problem.
I would be intrigued to hear the results of setting the correct stride length manually in the app or dashboard and then doing the walk again without any other changes
Strava
That's quite interesting. I will check once I do another run shortly. I do see that my stride length is set on auto which states that doing a connected GPS run will auto adjust my stride length. So I hope they are using GPS not steps*stride as with others on this chat, my steps are also off. If my steps are off, no matter the adjustment on stride length, the distance will be incorrect. So far this morning, my Charge HR and Charge 2 display the same number of steps 🙂
That depends on your setup in the phone app, under Exercise Shortcuts. For Walk, Run, or Bike you can Enable or Disable GPS.  If you enable GPS (on by default), using the Exercise Mode for Walk on your Charge 2, it will map your walk with distances using your phone's GPS.  It is very important, however, that the GPS be active on your phone BEFORE starting the Walk activity - there are several ways to do that, including opening the Fitbit app, click on Track Your Exercise, and click on the Stopwatch and wait for it to show the GPS active symbol. Or, you can open the Google Map application and wait for it to open GPS.
If you Disable GPS on the Exercise Shortcuts, then the Charge 2 will use your Stride Length and your number of Steps to calculate distance.
Larry
Thanks for the information, i checked the App and Connected GPS is enabled for Walk.
I can also confirm GPS was active and connected before every walk. In fact my walk yesterday where the distance was wrong picked up the GPS before todays where the distance was right.
Something has obviously changed the way the distance was calculated and seeing as the GPS Map was identical on both it does not make sense to me that the distance is calculated via GPS, otherwise the GPS data would show a vastly shorter walk
Strava
On my Excercise shortcuts the "Walk" and "Bike" are both set to "On" for Connected GPS.
In all the instances that I have used this feature, the GPS to my phone was connected as evidenced by the icons on the Charge 2.
The GPS "route" or "map" is spot on. But the distance walked is way off as shown in my previous post.
I will adjust my stride length, but it seems silly to have the GPS function on (much more accurate measurements) and not use it to calculate distance!
Thanks again for your suggestions @Nsmithson. I went through the steps suggested by Fitbit Support that you posed on 9-16 shown below:
  • Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
  • Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
  • Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display. Your Charge 2 will begin charging.
  • Press and hold the button on your tracker for four seconds. When you see the Fitbit logo and the tracker vibrates, this means the tracker has restarted.
  • Unplug your tracker from the charging cable.
I went out for the same walk around town hoping the results would be better.
No Success
The images above are from Fitbit and MapMyWalk. The distance shown with MapMyWalk is accurate. The results from from Fitbit are short by 33%. This is afterlengthened my stride on the device.
I do not understand why Fitbit is not using the GPS statistics for distance when it is a much more accurate representation.
I am begning to wonder if my unit is defective.
Any suggestions?
Well
My suspicions were correct, please see official response to my questions from FitBit support confirming exactly how they work:
1) When using the Charge 2 in Walk activity mode, How is the Distance calculated. Is this from GPS points or is this based on the stride length multiplied by the steps taken?
Your tracker calculate the steps based directly in your stride length and the vibrations that your walk produces, so the GPS is just for see the distance and the route you take.
2)  Does the FitBit App need to be running constantly on the phone? If No how does the app run in the background to keep GPS data?
The Fitbit app is necessary to be open at the moment you are performing an activity using the GPS, but is not necessary that you have all the time in the screen the app.
So essentially it is vital to get you Stride Length correct for the distance to calculate.
Hope this helps
Strava
My interpretation of the response is different than yours.
"the GPS is just for see the distance and the route you take."
To me this indicates the GPS should tell you the DISTANCE.
BTW, i'm having the exact same problem.  The top activity is from activating the walk directly from the fitbit application.  The bottom is from activating the activity via my fitbit charge 2.
Just completed the same walk as I have posted previously WITHOUT my phone and connected GPS.
Results are 5,676 steps and 2.69 miles. The Charge 2 is simply not counting steps accurately.
This, afer updating to Firmware Version 22.22.44.8.
Time to request a return to fitbit. I'll let you know how that goes.
Ryan
Did you make sure that the Stride length is accurate?
Strava
Yes. I have altered my stride length to compensate. No dice.
You should not need to set it to "Compensate" it should be set to be your
stride length correctly otherwise you will get wrong data.
I found it best to go for a walk of a few hundred counted steps (you count
not fitbit) and measure the distance exactly.
You can then use the calculations on the support pages to give you the
stride length you need to enter.
Anything off from this value and you will get wrong data as i did right
until i updated this
Strava
Nsmithson,
I sincerely appreciate your diligence in replying to my posts. Your involvment on this board will benefit many.
That said, I would think the content I've shared would suggest that I understand the impact of stride length on the results the Fitbit Charge 2 displays.
The problem with my unit is simply this... it is significantly undercounting steps.
This is my 4th Fitbit unit. I've owned two Charge HR's, a Surge and now this Charge 2. Of the four that I've owned, this unit has been by far the least accurate.
Fortunately, Fitbit has just issued an RMA # and I will preomptly return it to them for a refund.
Back to my Surge. Which, by the way... knows how to count steps.
Just to add to this thread. I take a regular walk that is exactly 4 km. Previously, if would track it with the iOS app to get the map and detail breaking down on paces per KM, etc when I had my Charge HR. Now with connected GPS, I figured I'd give it a try. Everything works except like many have reported, it doesn't report the distance accurately. I took 3 walks with the connected GPS and I get anything between 3.2 and 3.1km instead of 4. That's almost an entire 1 km short of the actual distance. It's pretty bad. I think it could be an easy fix. Instead of looking at steps/stride to calculate distance (obviously not working well), they should allow us to pick the phone GPS distance instead. would be an easy fix if they can't solve rapidly the issue. Right now, this is having mostly an impact on my distance goal which I'm missing now.
My issue with the GPS doesn't involve walking, but with running.  I ran my normal 4 mile route in my neighborhood with the Fibit GPS to get my VOMax calculations  The results were way off compared to my Garmin running watch.  Rather than running 4 miles I went 5.47 miles on the Fitbit Charge 2 and instead of having a 7:43 per mile pace the Fitbit Charge 2 registered me at a 5:40 per mile pace.  Although I would like to think of myself as an elite athlete I know what I'm capabale of as a runner.  I'm open to any suggestions to what I need to do to calibrate my Fitbit Charge 2 to work as intended.
