12-26-2016
15:25
10:13
12-26-2016
15:25
10:13
***SOLVED!!!! I had to enable preview pop-ups for texts on my phone***
I had to go into settings -> application manager -> messages (the app Im using) -> notifications -> then select previews in pop-ups so that these are enabled on your phone. I found when I chose Messenger on both my phone and in the fitbit app it worked so then realised it had to be a little change somewhere in the Messages app settings and thats what it was. Let me know if you get stuck ![]()
Hi - I have a Samsung Note 4 & have enabled/selected for SMS text messages to display the sender and message on my charge 2 and also turned notifications "on" on my tracker. I recieve a notification when I get a text but it does not go on to tell me who the sender is or what the message says. When I get call notifications it tells me the name of the caller but again not with a text/SMS. Any idea why anybody please?
Hi ive updated my comment as I figured it out and have written what I did. Hopefully it works for you too.
Best AnswerHi ive updated my comment as I figured it out and have written what I did. Hopefully it works for you too.
Best AnswerI'm glad you have it working.
Since there is no response with an edit of your first post.. There is no way to mark your answer as a solution, I've marked your response pointing to your OP as a solution.
Best Answer***SOLVED!!!! I had to enable preview pop-ups for texts on my phone***
I had to go into settings - application manager - messages (the app Im using) - notifications - then select previews in pop-ups so that these are enabled on your phone. I found when I chose Messenger on both my phone and in the fitbit app it worked so then realised it had to be a little change somewhere in the Messages app settings and thats what it was. Let me know if you get stuck
This did not work for me. I went to settings, then Messages and I don't have the "preview pop up option." I have an Iphone 6 . When I first put on my Charge 2 yesterday, texts and calls were working but now they are not. Any idea what I am doing wrong?? Thank you.
Best AnswerI have the same problem. I just got the Charge 2, 5 days ago. I got text alerts on the fit for a couple of days. Now nothing. I have IPhone 6 IOS10
Best AnswerMy partner has the same phone as both you ladies (iphone) and works in IT so il ask him to take a look at his phone and see what the set up is. I will get back to you 🙂
Best AnswerI have an iphone6. I have had the fit bit charger 2 for 3 months. I love it. 2 days ago it stop receiving notifications from Texts calls and events. I check my iPhone all the Notification planes are enabled. I didn't make any chances. I reviewed the posting and checked everything they suggested. Not sure what to do next. That's my favorite thing about the charager 2
Best AnswerSame exact issue here! Using iPhone 7 plus. I did not make any changes, and I am no longer receiving the prompts to get my extra steps in each hour, or any text or phone call notifications. Please help, this is getting frustrating!!
Best AnswerI am having the same issues as above users. i have an Iphone 6s plus and I used to get phone calls and texts on my charge 2 and I no longer get these....can you help. i don't see that you have replied to any of the iphone users on this yet....
Best AnswerI have the fitbit surge and I can get the notification that I have a text or call, but it will not tell me from who or display the text. I have a Samsung note 5 phone. The notifications are enabled on the device, my Bluetooth is on. The pop up messages are enabled on my phone. Can someone help?
