09-04-2022
13:10
14:21
AndreaFitbit
09-04-2022
13:10
14:21
AndreaFitbit
I have had my Fitbit Charge 5 for about a year and have had no issues. My battery life had been running 5-6 days. All of a sudden two days ago it is draining about 1% every couple of minutes. Needless to say that make it useless. I had made no changes to any settings. Any suggestions?
09-05-2022 08:10
09-05-2022 08:10
Hi, @WMW66 Allowing you contacted "Customer Support" as suggested by the moderator have they offered you a way forward?
Cheers
Gr4ndp4 | UK
09-04-2022 16:49
09-04-2022 16:49
I have the same issue, waiting on a answer to what I should do to fix this issue.
09-04-2022 19:20
09-04-2022 19:20
I've tried resetting and reinstalling with no results.
09-04-2022 19:30
09-04-2022 19:30
Same issue - less than 2 hours from 100% charge. It also started 2 days ago in the middle of the night. I installed the latest firmware update and reset from the settings on the device and nothing has changed.
09-04-2022 20:13
09-04-2022 20:13
My 4 and a half month old Charge 5 was great until it started this behavior about a week ago. Have rebooted thrice by either scrolling to the reset or hitting the charger button 3 times. No help. I used to get a week of battery, now a bit under a day. Can this be addressed, please?
09-05-2022 03:25
09-05-2022 03:25
Hi, @WMW66, @Wulfgarthegreat , @kcole02, @Poolboy1459 , see the last post in Solved: Charge 5 battery draining too fast - Page 77 - Fitbit Community
Cheers
Gr4ndp4 | UK
Best Answer09-05-2022 08:00
09-05-2022 08:00
If you are talking about the 'Best Answer' to that concern it is just a bunch of gibberish. Offers no help whatsoever. Simply some vague references to a firmware update that doesn't appear to be available except to a select few. And why would this problem just all of a sudden show up? It seems more likely that an update would cause the problem than solve it. In any case when I check the app says my Fitbit is up to date for what that's worth.
09-05-2022 08:10
09-05-2022 08:10
Cheers
Gr4ndp4 | UK
09-05-2022 08:30
09-05-2022 08:30
I just finished a chat with a customer support representative and they are sending me a replacement. Apparently the Charge 5's that exhibit this sort of behavior are defective. I would suggest others having this problem so the same. BTW - not all of the 'Customer Support' links work. It took me a bit to finally reach a chat but once I did the representative was efficient and helpful.
Thank you for being responsive. Good customer service is important but rare.
09-05-2022 12:42
09-05-2022 12:42
I had a chat yesterday that told me to adjust the GPS setting on the watch (I had no idea it had GPS) to offload it to my phone, which seems to have helped, but I've still lost %35 since yesterday. Will give it one more day.
Best Answer09-05-2022 20:54
09-05-2022 20:54
Ironically enough, mine started a day before the firmware update showed up. I installed it, reset the device both ways, turned off all the things and there's been no change. They are sending a replacement.
09-07-2022 03:22
09-07-2022 03:22
Bought charge 5 about 4 months back. The charge used to last for atleast 3 to 4 days. Since yesterday 100% charge is getting discharged within 10 minutes. All of a sudden one fine day .. any suggestions would help !
09-07-2022 03:50
09-07-2022 03:50
Hi, @Adutta, contact "Customer Support" as indicated in earlier posts.
Cheers
Gr4ndp4 | UK
Best Answer09-07-2022 07:29
09-07-2022 07:29
09-07-2022 08:08
09-07-2022 08:08
Thank you I will do that!
Best Answer09-08-2022 06:45
09-08-2022 06:45
Will do. Thanks !
Best Answer09-10-2022 16:34
09-10-2022 16:34
Just discovered that chat worked here only if I am already signed in on the forum. Had a brief chat and they want me to time how long it takes to go from 100 to 0%. Not a matter of great interest to me, but passes the time, I guess.
Best Answer09-12-2022 16:05
09-12-2022 16:05
Happy to report a straightforward replacement promised after jumping through a few hoops. Hope to get a good one.
Best Answer09-12-2022 17:06
09-12-2022 17:06
Best Answer09-13-2022 00:54
09-13-2022 00:54
Hi,
I have the same issue exactly two days ago battery started draining very fast can not last more then 15h I would say.
