Charge 5 - Some Upgrades
Charge 5 - need some new watch faces from cloud, its all boring. Please give some new faces in next update.
ECG app is often hang.
No ECG tiles in Dashboard for mobile app.
Please improve.
1 REPLY 1
Welcome to the Fitbit Community forums, @balajiIndia.
Thank you for sharing your feedback about the Charge 5.
It's always great to have more clock face options to choose from. If you haven't done so already, please consider voting for these ideas posted in the forums:
Regarding the option to have an ECG tile in the Fitbit app, I would recommend that you post this idea in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
About the inconvenience you mentioned with the ECG app, could you please provide mode details about this problem? In the meantime, make sure that you've tried the three pulse restart method described here below:
  1. Connect your device to the charging cable. For instructions, see How do I charge my Fitbit device?
  2. Press the button located on the flat end of the charger 3 times, pausing for 1 second between presses. Then wait 10 seconds or until the Fitbit logo appears.
Thank you for all the feedback provided about the Charge 5.
Hope this helps, I'll be around.
