10-24-2024
10:12
14:54
FatimaFitbit
10-24-2024
10:12
14:54
FatimaFitbit
Hi. I noticed yesterday that my charge 5 was not syncing to my phone. I tried to resync it several times and it did not update on the phone. Now in the past when something like this happened, I was able to unpair the Charge 5 and re-pair it. I un-paired it, but I could not re-pair it. I tried all the normal troubleshooting. I reset the Fitbit, I turned off and turned on the bluetooth on the phone, I tried turning off the phone and turning it back on, I tried uninstalling the fitbit app & reinstalling it but nothing happens. When I look at the available devices under the bluetooth setting, I see the charge 5, but when I try to find it within the app, it can't find it. It just keeps searching. Right now, it's been searching for 20 minutes with no results. Did something change recently that would cause this or do I just need to bite the bullet and get a new fitbit? Any help would be greatly appreciated.
For the record, I have a Samsung A-13 phone running android 14. My fitbit app version is the latest on the android play store and it was last updated on Oct 10th.
11-01-2024 14:57
11-01-2024 14:57
Well folks. Here we are on the 1st of November and lo and behold, the .3 version actually works! I was able to successfully pair my fitbit to my phone (A13) and it seems to be working great. My thanks to the technical team over at Fitbit/Google. As a former IT professional, I know when things go bad, sometimes it takes a while to get things working again (and yes, Sometimes it takes several updates - I know from personal experience that sometimes, even if you tested and things work for you, things sometimes don't work for everyone and you need to step back and figure out where you still are going wrong) Thank you again
10-24-2024 12:30
10-24-2024 12:30
Hello @kaseyi
There are several Charge 5 users who have reported that they aren't able to sync to the Fitbit app. Please see this thread (<-- click link). I've put in an inquiry about this issue but haven't gotten a response yet.
Although I'm not sure that they have any information, it might be worth contacting Support (<-- click link) to report the issue. Complete the prompts until you get the option to chat or call.
10-24-2024 12:45
10-24-2024 12:45
Thanks for the reply. Yeah...after I posted, I saw the other threads. I apologize for not looking sooner. I saw I was not alone. I guess we just have to wait for the power to be to fix the app. Thanks again
Best Answer10-24-2024 12:59
10-24-2024 12:59
Hi @kaseyi
No need to apologize. It's all good.
I encourage you to post on the other thread. I'll post updates there if I get any information.
Best Answer10-24-2024 13:34
10-24-2024 13:34
I have the exact scenario with a Versa 3 and Versa 4 . I also have the same phone Samsung A13 with the same software Android 14. You need a minimum Android 10 to run the App so this should be OK. Maybe the type of phone is impacting how the app is running? I've had no problems till last week so must be related to App or server!!!!
10-25-2024 10:44
10-25-2024 10:44
Hello @RicFix
From the posts I've read, there is a known issue that affects syncing with the app for Android users. It seems that the problem started around the time the users updated their Fitbit app to version 4.28. The team is aware of the issue and has been working on fixing the problem.
FWIW, I've seen some users reporting today (25 Oct 2024) that they are able to sync again.
Please let us know if you are still having a problem with syncing.
Best Answer10-25-2024 11:41
10-25-2024 11:41
Samsung A13, same problem, can't connect after i unpair my Charge 5. Before that, i couldn't sync for the last 2-3 days.
10-25-2024 11:47
10-25-2024 11:47
Samsung A13 here also - tried rebooting, resetting, re-installing everything before finding this info. Hopefully will be fixed soon.
10-25-2024 12:05
10-25-2024 12:05
Yes this is very annoying. 3 fitbits and I cannot use any of them. Now the watch starts to loose time because it is not synched to the App. 6 mins slow now. Fitbit have not made any notifications about the current synching issues. I presume this is all related to the recent App updates and may also be linked to specific models of phone. So now we have at least three A13 Samsung showing this issue. Just waiting for a new App release to appear
10-25-2024 12:13
10-25-2024 12:13
yes unable to sync but now cannot add any of my Fitbits. When swapping devices it fail to reinstall othe Fitbit so now have no device in my App and unable to add any as it can never detect any of my fitbits. I tried all of the reset, re-install, disconnect methods nothing works.Waiting for App update!!!!
10-25-2024 12:14
10-25-2024 12:14
Best Answer10-25-2024 15:45
10-25-2024 15:45
My Charge 5 has the same issue today. I also noticed that I have started to get messages from Google to encourage me to move my account to Google rather than keep it in the Fitbit app. My guess is that there has been a programming change to force users to move the account (and hopefully our data... I've had a fitbit for 10+ years) to the new Fitbit owners, the great monopoly Google. And they unfortunately always win. They will see the tried and true Fitbit users bail to another watch/monitor.
Sad.
10-25-2024 15:56
10-25-2024 15:56
I have the same issue couldn't sync and now after following suggestions cannot pair my Samsung Galaxy A13 with my Charge 5. This started after my phone did an update I'm now on Android version 14
10-25-2024 23:05
10-25-2024 23:05
I have the Charge 5 with a Samsung Galaxy A13 as well. I too am wondering if it's this specific phone. Because mine was all fine 3 days ago. I've literally spent 7 hours over the past 2 days trying to sync my fitbit. I’ve done EVERY SINGLE troubleshooting suggestion not less than 10 times. I'm beyond frustrated and all to boot, now the battery won't last 24 hours!!
10-25-2024 23:07
10-25-2024 23:07
4 Samsung Galaxy A13 with mine now too.
Best Answer10-26-2024 04:14
10-26-2024 04:14
Still not syncing on Samsung A13. Does on Samsung A12 mind you.
10-26-2024 04:26
10-26-2024 04:26
Totally agree with your sentiments Rhetaroo. I cannot sync my charge 5 and have also declined to move my account to Google . For the record I am using a Motorola so not sure the type of android phone has anything to do with the problem
Best Answer10-26-2024 04:45
10-26-2024 04:45
My sense 5 is also not syncing on a Samsung A13. It would great if fitbit could give us an update.
Best Answer10-26-2024 05:32
10-26-2024 05:32
Any chance you’ve seen iPhone users experiencing the same issue? I guess maybe they gave android users back their sync & took it away from iPhones lol because I can’t sync as of Friday.
Best Answer10-26-2024 07:09
10-26-2024 07:09
well..seeing other people were able to make progress, I tried to pair up my Charge 5 and it still won't pair. Oh well, guess I still have to wait
