All morning my charge 5 won’t sync to my iPhone 11. I’ve gone through every step including uninstalling the app, turning blue tooth off and on, pairing again, restarting both devices. Only thing I haven’t done is a factory reset which I had to do last month when alarms stopped working and I don’t really want to do again if that’s not the problem.
Mine is syncing as usual since Tuesday 20:00 (Amsterdam time).
Best AnswerSyncing but same battery drain issue..
Best AnswerMine never recovered. Finally got it to sync, but watch froze halfway through the update Fitbit said had to be applied. After 3 days of back and forth with support, it has to be replaced. Hope the replacement works better.
Best AnswerMy charge 5 started to sync again eventually on 16/8/22. Has now stopped syncing again, and no heart rate registering again!!
17:47
06:12
DavideFitbit
08-18-2022
17:47
06:12
DavideFitbit
well, the **ahem** is dead in the water.... it worked maybe 8 hrs yesterday before, now... nothing... just sits there with the logo on.... refuses to connect to bluetooth, can't reset because after 3 button presses, goes dark and right back to logo... and it sits.... totally useless and with all the chatter here it doesn't look very promising... the support is a joke... and has been useless.. nothing they have suggested has worked successfully...
don't hold your breath.. mine came back for 8 hrs and is now hung up on the logo screen..... refuses to connect to bluetooth even though every other bluetooth device I have is working...
Mine is still working fine with iPhone 13.
hope you all get it to work as usual as well, good luck!!!
@Giavee wrote:I see apple had a new update today. iOS 15.6.1 now I’m concerned if I updated then my Fitbit will stop.
is that going to happen again?
I'm running iOS 15.6.1 and so far no problems.
Mine did start syncing again on the 16th, but has again stopped working this morning. It is the charge 5 and the iphone 13..
Update:
It is now syncing again after a couple of hours of trying it.
Best AnswerWhere is the support??
Can Fitbit not just undo the mistake they made last week?
05:33
16:43
YojanaFitbit
08-20-2022
05:33
16:43
YojanaFitbit
at least yours does that. Mine won't turn on at all. What an embarrassment this company is. Would you ever buy something from them again? I'm a big "NO" on this, but there's not anyone I can tell since FITBIT doesn't actually offer human being support.
Yeah...no. Not one feature works, including just the simple watch.
Moderator Edit: Merged posts.
Hang tight. I have been on a chat with customer service rep "Carlo and the team" over the past few days. He has gotten back to me through the chat and email. Although I can sync, the battery drain is a big problem and I let him know that. He said they are working on a firmware update to fix the issue.
10:25
16:46
YojanaFitbit
08-20-2022
10:25
16:46
YojanaFitbit
We are all losing track, or lost track, as to what firmware release fixes
Does anyone know?
Thanks
Moderator Edit: Word choice.
