04-21-2026
12:00
09:06
MariLuFitbit
04-21-2026
12:00
09:06
MariLuFitbit
04-22-2026 04:35
04-22-2026 04:35
I woke up this morning and found that not only is there a problem with tracking food, but also water. With food, my entries are listed but the totals are not appearing on the main screen. With water, my entries are just not there at all, anywhere.
04-22-2026 05:52 - edited 04-22-2026 05:53
I'm having the same issue! Started happening between 9am and 1pm today (UK time)
04-22-2026 07:43
04-22-2026 07:43
Same issue, sometimes the additional food will appear, then when you try and look at details it returns, "unexpected error"
04-23-2026 03:23
04-23-2026 03:23
Getting exactly the same "unexpected error"
Does anyone know how we can actually report this???
04-23-2026 04:16
04-23-2026 04:16
I wanted to give it 24 hours before looking into how to report the issue. This morning, so far, it is tracking my food and water entries properly. Hope that is true for everyone else here as well.
04-23-2026
11:10
09:08
MariLuFitbit
04-23-2026
11:10
09:08
MariLuFitbit
Three to four days of the same frustration with food & water entries. Who even knows if the steps are even correct. I’ve tried all the suggested fixes and nothing has corrected the problems.
Unfortunately I’m still experiencing the problems with food & water entries. Some disappear, some add 4-5 times and totals are incorrect. Water has been disappearing completely. This has gone on for about three days this time.
04-23-2026 11:51
04-23-2026 11:51
Yesterday I uninstalled and reinstalled the app. Today it is behaving normally. If you haven't tried to uninstall/ install yet, maybe do that and see what happens. It can't hurt.
04-23-2026 11:56
04-23-2026 11:56
I did that, as well as all the usual fixes that are always recommended ( because these happen so FREQUENTLY!), but the only thing that seems to help is by switching to the Public Preview app version, which I'm not a fan of. When I switch back to the original version, my food is still messed up. And I don't have any other connected apps either, I only use Fitbit.
04-23-2026 12:15
04-23-2026 12:15
Are you using the public preview of the new app or the old version? I have been getting disappearing hydration logs (water) in the preview of the new one. It disappears then reappears. Food logging is really really clunky in the new version btw. Takes twice as long.
04-23-2026 12:20
04-23-2026 12:20
It's the public preview to see new features before they're released. I honestly don't log my hydration because I drink a LOT of water and know I exceed my goals.
04-23-2026 12:37
04-23-2026 12:37
Havingbtgr same issue! The home (Today) screen shows 0 calories. When I click on Food, the calories logged are showing but without details (no macro nutrient info etc). It also is not synching with Trainerize
04-23-2026 12:41
04-23-2026 12:41
I am using the old version. I haven't opted in for the beta, though I've been asked twice.
04-23-2026 12:41
04-23-2026 12:41
I am on a medication that specifies I need to drink 2-3 litres of water per day so I need to make sure I get enough, but equally it's not good on this medication to drink too much. I actually need an accurate water logger. Have you noticed the calories thing has changed to a static target. So annoying!
04-23-2026
12:42
09:14
MariLuFitbit
04-23-2026
12:42
09:14
MariLuFitbit
I use the water logging because I am on a fluid limitation of 2000ml per day. It's worked out very well for me.
Here is a link to the Fitbit Contact Us Support Line: https://support.google.com/fitbit/gethelp?hl=en I strongly suggest contacting them!
04-24-2026 09:04
04-24-2026 09:04
This has been 4 days now. Are they going to get this fixed????
04-24-2026 09:28
04-24-2026 09:28
Hi everyone, nice to see you all! Let's give a warm welcome to our new members.
Thank you so much for all the reports shared so far; they are truly helpful! Let me tell you that we are aware of this issue and are actively working on a solution.
I'll post updates here as soon as I have them. In the meantime, please ensure your devices and app are updated.
04-24-2026 09:37
04-24-2026 09:37
I've been using the Fitbit app on Android since early February, and this issue has recently started to affect me. It's gotten pretty frustrating now, because I loved how simple it is to log food/calories in this app. I just found a thread in here from 2016 with multiple users describing the same issue. That's ridiculous.
04-24-2026 10:36 - edited 04-24-2026 10:36
True, this issue has happened in the past. But my experience has been that it gets resolved quickly. I cannot speak for others. I've been using the app since 2021.
Best Answer04-24-2026 11:32
04-24-2026 11:32
It is now day 3 for me. I downloaded the latest version, which I had been told on the phone, should have resolved the issue but didn’t.
I am noticing the following:
1. Certain products show in the log three times after only being added once (for example every time I log tofu from TJ, it shows as three separate logs (tripling the calories etc).
2. There is a considerable delay between different views. In the past after adding a food, it was reflected immediately in the Today Home Screen. Now I have to force shut the app, open it and hope for the best.
3. Synching with Trainerize is NOT working. Trainerize only sees some of the items I’ve logged through Fitbit. Yes, both apps are updated and I even offloaded them, disconnected and reconnected several times - synching is still messed up!
