04-13-2026
09:10
13:17
MaCrisGBFitbit
04-13-2026
09:10
13:17
MaCrisGBFitbit
Seems that some data was lost. Sleep hasn't recorded. It connect to my watch. I've Uninstalled it and re-installed it, force stop, removed it from Bluetooth and app and now it won't reconnect. I've also held the side button of the watch while it's connected when ive tried to re-pair it but it won't.. I get an error with a "try again" and "cancel" option.
Thank you for your reply @MCue777 !
We have tried all possible steps through this channel to try to resolve this issue. My best suggestion is that you contact technical support directly, as they have more tools to provide you with the appropriate follow-up.
Hi @MCue777! Welcome to our community forums!
I'm sorry to hear that you are unable to connect your Charge 6 with the app and the issue with the side button.
It is necessary to verify that the requirements for pair the tracker are met:
Check again the following information about your mobile device:
Once you have verified the requirements, please follow the steps in the article below: Why can't I set up my Fitbit device?
Additionally try to clean around the button and verify if there is dust stuck.
Hello, thank you for the reply. I have done all the above you suggested but it still won't reconnect/pair. Please help. I am frustrated already.
Best AnswerHello, the technical support link had a link to a YouTube video and the one thing I had not done ans didnt know I could do was to reset/restart the watch itself through the "setting" button. It finally was visible to the app and it paired successfully. It did, however, lose some data like months of my weight that I had inputed. Thank you for your help.
