03-25-2024 22:08
03-25-2024 22:08
My three month old Charge 6 has stopped taking a charge. Contacts for device and cable are clean and undamaged.
Best Answer03-26-2024 03:54
03-26-2024 03:54
Hi, @Peterdouglas , sometimes a Fitbit seems not to be charging when (for whatever reason) it has become unresponsive instead. In this case I would give it a couple of hours charge using a plug and socket known to be working. When it has been on the charger for a good two hours - even if it doesn’t seem to be charging - give it a restart . You may have to try the restart a couple of times but hopefully it will spring back into life and all will be well.
If after a couple of hours charging and several restart attempts the Fitbit is still dead then I would recommend getting in touch with Fitbit Customer Support on Contact.fitbit.com . Be sure to tell them the trouble shooting steps you have already tried.
03-26-2024 03:54
03-26-2024 03:54
03-26-2024 10:52
03-26-2024 10:52
Thanks Julia,
That was it!
Pete
Best Answer03-26-2024 11:03
03-26-2024 11:03
Hi, @Peterdouglas , I am super glad that that solved your problem. In that case it would be great if you could mark my post as a “best answer”. It will help other users searching for the same issue, and also apparently will make Google like me better 😄.
03-26-2024 11:26
08-21-2024 03:21
08-21-2024 03:21
Just received a Charge 6 as a gift. It won't charge. Only got to 37% and quit. Tried everything. Too difficult to work with. Returning it.
08-21-2024 07:55
08-21-2024 07:55
A warm welcome to the forums @Vv77.
Thank you for letting us know the difficulty that you are experiencing with the device.
May I know if you followed the advice given by @Julia_G above?
Before returning the device, I'd suggest you take a look at the points listed in this help article: Why isn't my Fitbit device's battery charging?
Please, confirm that you have tried to restart the device as indicated here:
08-21-2024 18:09
08-21-2024 18:09
Shouldnt have to go through steps to charge a device. The device will not restart, nor will it charge. Unusable. Disappointed. Returning device.
Best Answer05-25-2025 12:14
05-25-2025 12:14
Didn’t work I couldn’t find a reset button on the charge because the only charger is a generic charger that takes charging cords. However I used “unbind” and reset the connection to Bluetooth. It is finally charging after multiple attempts.
06-17-2025 06:11
06-17-2025 06:11
My Fitbit charge 6 is also facing the same issue. I tried everything so far and it still won't power on. Based on the reply on this page, I tried contacting customer support but I'm not getting any link to do that.
Best Answer06-17-2025 09:52
06-17-2025 09:52
Best Answer06-17-2025 10:09
03-13-2026 12:06
03-13-2026 12:06
Thank you, this solved my issue. Thought my Fitbit was done for, thank you very much!
