03-03-2025 01:28
03-03-2025 01:28
Stress Score not tracking.
My charge6 has stopped tracking my stress score as of Feb 27th.
I have uninstalled and reinstalled the tile but still not working
Fitbit always on my wrist. Heart rate tracking enabled etc…
any suggestions on how to fix please
03-03-2025 05:28
03-03-2025 05:28
Sounds similar to my issue. My readings were way out of whack mid-February after the Super Bowl. Then things stopped giving readings each morning. I bought a new fitbit, thinking my 2 year old device was the problem. Still missing the same data each day with new watch. I think Google needs to fix the app or something.
03-03-2025
09:56
18:46
ManuFitbit
03-03-2025
09:56
18:46
ManuFitbit
Similar,
Mine worked for years, through multiple devices, and just stopped reporting stress score four days ago, although all other data is displaying correctly. No updates are pending, I restarted my fitbit, whcih did not help. Wear my device practically 24/7.
Additional observation - there was a fitbit app update to version 4.37 - about the same day the stress score stopped calculating - maybe there is a relationship and a bug that needs to be fixed.
03-03-2025 10:00
03-03-2025 10:00
03-03-2025 11:12
03-03-2025 11:12
Hello @jbvalor , @GreggS48 , @AnnefromMI
There are multiple reports about this issue. I'm also experiencing this issue. Several of us have submitted the issue for escalation so the team is aware of the problem.
We are advising users to report the issue using the Feedback option in the Fitbit app:
Although it's likely that you won't receive a response, the team receives & reviews the feedback reports.
The Moderators usually pick a thread to acknowledge the issue and will use that thread to post updates. When I find which thread they're using, I'll report back with a link so you can follow the thread.
03-06-2025 17:33
03-06-2025 17:33
According to the Moderator's post in this thread (<-- click link), the issue has been fixed.
If you still don't see a stress management score tomorrow (07 Mar 2025), please post in the thread above and let the Moderator know you don't see your score.
Best Answer03-06-2025 18:46
03-06-2025 18:46
Hi Everyone. Thank you for letting us know the difficulty experienced with Stress management score.
We received the update from our team and the issue should be resolved by now.
Please restart your phone and give it a try .
Please confirm here if it got solved for you or if you are still encountering difficulties.
03-06-2025 19:42
03-06-2025 19:42
Hi, I did not get a Stress Management Score today. I restarted my phone but still no score. Thank you.
Best Answer03-07-2025 14:20
03-07-2025 14:20
Hello @DVarga
Did your stress management score appear this morning?
I don't think the fix was retroactive and you won't see scores for the days where the score was missing.
Best Answer03-07-2025 14:28
03-07-2025 14:28
03-07-2025 19:42
03-07-2025 19:42
Hi Everybody.
Thank you for being aware of the situation. If some of you have not yet received the Stress Management score please make sure of the following:
Best Answer03-09-2025 05:27
03-09-2025 05:27
Best Answer03-09-2025 12:38
03-09-2025 12:38
Hello @AnnefromMI
Have you had a chance to check the Settings tile on your Charge 6 to confirm that Heart rate is turned on? Sometimes, the sensor gets turned off without us being aware of it.
Best Answer03-09-2025 13:25
03-09-2025 13:25
Best Answer03-09-2025 14:06
03-09-2025 14:06
Hello @AnnefromMI
Thanks for confirming that Heart rate is enabled on your Charge 6, but you still don't see a green light.
I've seen users report that Support had them do a factory data reset and that restored their green light/heart rate sensor. That's an option if you want to try it. If you want to see if this works for you, this help page (<-- click link) has the steps to follow.
Since it sounds like you might be still in the return window, it might be better to return the Charge 6 for a refund or replacement.
Best Answer03-09-2025 19:08
03-09-2025 19:08
05-26-2025 15:34
05-26-2025 15:34
Mines is not working yet
Best Answer05-26-2025 15:35
05-26-2025 15:35
Doing all.this and its still not working
Best Answer05-26-2025 15:55
05-26-2025 15:55
Hello @Janicewright
We are escalating the issue of missing stress management score to the team and will report back when we have an update.
Best Answer05-26-2025 16:18
