01-21-2016 17:43 - last edited on 09-06-2020 17:10 by MatthewFitbit
07-16-2016 16:54 - edited 07-16-2016 16:55
I had to factory reset my FitBit Charge HR to connect to anything. Not sure what happened but thats what it took.
Just go a simple google search for Factory Reset Fitbit, Uninstall the APP, Connect FitBit to PC after reset, Follow Instructions on how to update fitbit from PC, Reinstall FitBit App, Reconnect to Phone. Boom!
09-20-2016 23:14
09-20-2016 23:14
this didnt work. it keeps saying that its connected to another device. I turned the bluetooth off of the 2 devices I have the app on, as well as have turned them off. it cant find my tracker. I have also restarted my fitbit 4 times. nothing is working. super frustrated
09-21-2016 07:25
09-21-2016 07:25
Hello @Bill_42, how are you today? I appreciate the instructions you posted! They are really useful 'cause some users might have paired their tracker through the Bluetooth on the phone, and that is not the correct procedure so then they have to forget the device.
@MarkJW82, I appreciate you have taken the time to troubleshoot your tracker. Tell me, did it update? is it syncing properly?
@short_stack, welcome to the Community! So when you are trying to update the Firmware of your tracker, does it say "connected to another device"? Let me suggest you something, since you already tried to restart your Fitbit, now try to set it up with your Android device by following the instructions on @AlejandraFitbit post and if it wont update, please try to update the firmware by using a computer.
Let me know the outcome guys!
10-12-2016 12:03
10-12-2016 12:03
I have restarted my device about 5 times, bout the tracker still fails to be updated.
10-13-2016 07:51
10-13-2016 07:51
Welcome to the Community @Lawzzaa!
It's a shame to hear that you were not able to update your tracker. If you have already tried the steps that @HeydyF shared on her post and the issue persists, I suggest contacting the Support Team they'll take good care of your tracker.
Let me know how it goes!
11-25-2016 11:04
11-25-2016 11:04
11-27-2016 05:47
11-27-2016 05:47
Welcome @Damgab, it's nice to see new faces in the Community!
I'm glad to read that you were able to fix the issue with the update and thank you for the time you took to do troubleshooting steps.
I'd like to invite you the our Community Discussions Board where you can find other Fitbit users sharing their ideas, recipes and motivation to a healthy style life.
I hope to see you more often in the Forums!
What's for breakfast?Check others recipes and share yours!
04-13-2017 12:34
04-13-2017 12:34
I was able to update the charge 2 by having the charge plugged into the usb on the computer during the update process. Perhaps the battery in the charge wasn't fully charged.
04-14-2017 06:03
04-14-2017 06:03
Hey @MargJ2, it's awesome to have you as a Community member!
I'm really glad to know that you were able to complete the update for the Charge 2, actually this process always take a lot of battery to be completed and have it plugged while updating is a great idea. I'll let other users know this awesome finding you did!
If you have time please check our Discussions board where you will find other members sharing their experiences and tips for an active lifestyle.
Hope to see you around the forums.
05-29-2018 19:39
05-29-2018 19:39
This is the first thing that worked! Thank you so much!
05-30-2018 11:19
05-30-2018 11:19
Welcome aboard @Jessminda11!
I'm glad to hear that you have it sorted out. Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
See you around!
07-12-2018 08:51
07-12-2018 08:51
Maxjwinters
04-28-2019 06:14
04-28-2019 06:14
You can’t turn off the device while it’s updating. You can’t logout while it’s updating. So please tell me how this is supposed to be a solution.
