03-16-2017 06:03
03-16-2017 06:03
I'm new and have no idea how to add a post to the https://community.fitbit.com/t5/Be-Inspired/Looking-for-Fitbit-Friends-Find-some-here/td-p/1257283/j...
03-16-2017 06:58
03-16-2017 06:58
It is quite easy, @Jane_N_Roses. To add a new post, open the forum and click on the Start A Topic link at the top of the threads.
To reply to a current comment, just click on the Reply link at the bottom of the post.
03-16-2017 06:58
03-16-2017 06:58
03-16-2017 09:03
03-16-2017 09:03
Thanks, but how do I add a comment to a discussion that is already going?
I don't want to start my own topic or reply to current comment. I hope that makes some sense
03-16-2017 14:41
03-16-2017 14:41
@Jane_N_Roses, just click on that REPLY link to open a new message window and then type away...click POST when you're done.
03-19-2017 17:03
03-19-2017 17:03
If there's no reply button does that mean it is blocked from doing so ?
03-19-2017 17:07
03-19-2017 17:07
@Lj92 wrote:If there's no reply button does that mean it is blocked from doing so ?
Yes, it is either closed or restricted access.
03-21-2017 04:53
03-21-2017 04:53
Thank you
03-28-2017 07:15
03-28-2017 07:15
I cannot do anything here in Community with my main account, I get the red box saying error loading page. I searched and it said it had been solved in september but I cannot login to community as my normal account. From Dashboard, I click Community and I am logged out I try logon and get looped to the red error screen. All browsers! This account is hit or miss
05-02-2017 11:26 - edited 05-02-2017 11:37
What am I missing. I am new to the community.
There are several discussions that I would like to comment/ask in and yet the only reply buttons are on already comments in the discussion group.
How do I comment in a discussion and not on an existing comment in the discussion?
I hope that made sense.
Tex
up date... just figured out that each reply on each post for the discussion is a reply to the discussion and not the post.
sorry
05-02-2017 11:38
05-02-2017 11:38
@TexNolan, just click on the Reply Button in the latest post in the thread, and it will open the message window where you can add your comments. I does not reference the post you selected "reply" in, so you need not refer to it unless you wish to.
05-09-2017 11:27
05-09-2017 11:27
I posted a reply to a post in the community forum and I got a notification but when I clicked on it, it disappeared and nothing happened. And now I cannot find the posts I replied on. Or if someone posted in response to my post.
05-09-2017 12:32
05-09-2017 12:32
@Ninie08, your profile says that this is your first and only post. Open your profile page (click on the Profile icon in the upper righthand corner of this page, and select "Profile"), then scroll down to see if the message you created was auto-saved there. You may have not clicked on the "Post" button after you created the message.
05-09-2017 19:43
05-09-2017 19:43
Hi! Thanks so much for the prompt reply. That was my first post here.
But I was referring to posts made in the Fitbit app-> Community. Someone posted something about sleeping, for example and I responded with a possible solution... I did this a few times but I can't find those posts.
05-10-2017 21:19 - edited 05-10-2017 21:20
@Ninie08 In the fitbit App Community you should get a notification if someone responded to you. When that happens just click on that notification and it will take you there.
Otherwise I find it very hard to find what I posted to. I know of no way to do so either.
Wendy | CA | Moto G6 Android
05-18-2017 18:58
05-18-2017 18:58
I cant even find start a topic location. I am so frustrated trying to fix my fit bit I am ready to toss it. Help please.
05-18-2017 20:33
05-18-2017 20:33
@stresseduserWe need to know whats wrong so we can help
05-19-2017 14:13
05-19-2017 14:13
Start a topic is grayed out for me.
05-21-2017 03:13
05-21-2017 03:13
How do you go to forum to post a question. I don't see a Start a topic link?
Have questions bout my new Altra HE this is the first time to fitbit
Thanks
05-21-2017 03:14
05-21-2017 03:14
I have same problem I can't find Start a topic
05-21-2017 11:21
05-21-2017 11:21
When I entered my Username, it said I should post something to see something in "notifications."
