03-02-2020
15:41
17:08
03-02-2020
15:41
17:08
I have an Alta HR which connects and receives calls and text notifications but I've been unable to get the same for Flex 2. Have done everything - phone reboot, reinstalling app, resetting device, turning Bluetooth off and on etc. Support not provided any help. I am about to return it but my last resort is to ask for any suggestions? Thanks
03-03-2020
11:30
06:03
03-03-2020
11:30
06:03
@Babs2Cricket Welcome! It's nice to have you on board!
Let me help you with your Flex 2 not getting notifications and thank you for troubleshooting this issue. Which phone are you using? Is it compatible? Note that if you are using an Android device and have both trackers nearby then notifications will only reach to one device as stated here. You can try refreshing the link between your phone and your tracker by doing the following:
Let me know how it goes.
Best Answer03-03-2020 13:05
03-03-2020 13:05
11:11
06:03
03-04-2020
11:11
06:03
@Babs2Cricket thank you for the update. You did add something interesting about this issue. You mentioned that your Flex 2 received a call notification from your iPad. When using notifications your devices will only get notifications from a primary device (phone/tablet). In this case I suggest you repeat step 1 from my previous post in both your iPad and your phone and then setup notifications for your Flex 2 on your phone only.
Keep me posted.
Best Answer03-05-2020 06:26
03-05-2020 06:26
