04-07-2020
06:18
17:08
04-07-2020
06:18
17:08
I haven’t used my Fitbit Flex 2 in a few months. I put in on the charger last night but it appears that it never charged. So I tried plugging it into a different charger. It does not vibrate at all and the lights are just flashing fast over and over.
04-28-2020
11:15
08:10
04-28-2020
11:15
08:10
@MsMell78 It's great to see that you've visited the Fitbit Community! Sorry for the delay in my reply.
Let me help you with your unresponsive Flex 2 and thank you for troubleshooting this issue. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
