01-07-2020
21:45
17:15
01-07-2020
21:45
17:15
Ok so I'm having issues with my lights not going off when done charging and it say 100% charged but if I tap on it it only gives me a red light and it won't sync and steps. Any help?
01-08-2020
06:54
09:12
01-08-2020
06:54
09:12
@Chasityborn Welcome! It's great to see you around!
Let me help you with your Flex 2 not properly charging nor syncing. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.
Regarding the syncing issues you can try the following:
Let me know how it goes.
