10-24-2016
14:31
17:15
10-24-2016
14:31
17:15
Please help, i have had my fitbit for aprox a week. Everything was great but all of a sudden yesterday it has stopped syncing with my samsung phone. This is really frustrating! As far as i can tell the fitbit is still tracking me but just stopped syncing. I have tried everything suggested on the webpage (bluetooth, disconnect bla bla) please help
Best AnswerThank you, Thank you, Thank you, I just got my Fitbit Flex 2 and it was not syncing only had it for a day but thanks to you is fixed I just wish I would have read this first before deleting apps refactory my phone pulling my hair lol well thank you so much for helping!
Best AnswerSo all of a sudden my LG G6 isn't supported and none of the currently available Android phones I would buy are supported either???? Pixel 2, G7, V30.....? So I bought this thing and it's useless all of a sudden.
Best AnswerI went to go sync my Fitbit Flex 2 on my Android phone and I was going to show my friends on Fitbit that my new exercise I was trying and it will not sync at all..that was today
Best AnswerI have always had problems syncing my Flex 2 using the app on my Lenovo P2 phone. It usually ignores request to sync, and instead syncs automatically at apparently random intervals. It also sometimes complains of "bluetooth issues" when no such issues exist. On the other hand when I sync using my Samsung Galaxy S2, it works every time. It usually also connects to the Flex 2, and shows the number of steps in real time. I have never managed to get this to happen on the Lenovo P2.
Clearly there is nothing wrong with the Flex 2 itself. The problem is the flaky software with some Android devices - which clearly includes your phone as well as mine.
Best AnswerWhat phone are you using?
Try the suggestion in THIS Help Article on syncing issues
Helen | Western Australia
I don't want to loose the data from my previous 2 weeks and today. Fix the app. Looks like this happens a lot!
Best AnswerMine too. I just started using a Fitbit two weeks ago. I don't want to reset and loose my data. They had 2 fixes to the app last week. Must have broken Flex2 syncing.
Best Answer@lvnew restarting your tracker will not lose you any data. It is like restarting a phone.
Best AnswerSame thing happened to me. Just stopped syncing out of the blue. Tried all the fixes on the website and again when customer service had me try all the exact same things. They sent me a replacement that worked for less than a week and now the same issue is happening again. So frustrating!!
Best AnswerI have done everything that you all suggested and still my flex2 will not sync! Grrrrrr…..
Best AnswerPS I also bought a dongle so don't offer that either --I think I'm going Garmin.
Best AnswerI did that and it did work but only for 2 days
Best AnswerForce quit and then reopen the Fitbit app. - This worked for me. My flex2 had stopped syncing for nearly 2 months.
Best Answertoday when I double-tap the Flex 2, it does not work and no light twinkled. when I reach my home, plug it into the charger and it starts vibrating constantly with 3 white lights and 1 orange/yellow light at the end. I unplug and replug it and it became ok. Then, it wasn't in my Bluetooth and I cannot connect with it. Worse than that, I search everywhere for a possible solution and I find your link here for tackling this problem. However, when I click on the link it says "Sorry, you don't have permission to access this page".
