01-16-2020
		11:58
		17:15
		01-16-2020
		11:58
		17:15
Hey has anyone had problems with syncing an okok international scale with Fitbit? It gives the option to do it, it diverts my iPhone 6 s plus to the Fitbit website to approve and then just...nothing. I’ve contacted okok but heard nothing, I’ve turned Bluetooth on and off, reinstated Fitbit after deleting and tried to delete and re-pair scale. Nothing works
		01-17-2020
		07:22
		08:10
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
		01-17-2020
		07:22
		08:10
@JessC78 Welcome! It's great to see you around!
Let me help you with your OkOk integration. Try logging out from both apps, restart your phone and log back in. After this retry linking both accounts. Still please let us know what OkOk support suggest you to do.
Let me know how it goes.
 Best Answer02-09-2020 15:48
02-09-2020 15:48
Did you found a solution?
 Best Answer02-09-2020 15:55
02-09-2020 15:55
No it was a piece of crap. I had them refund me and i got a different scale which syncs perfectly with Fitbit. The other scale just wasn’t working any which way
02-19-2020 16:13
02-19-2020 16:13
Thanks for your reply.
🙈Haven't tried mine yet, will try this weekend and see if it works.
 Best Answer07-07-2020 08:53
07-07-2020 08:53
Hi, I"m having the same problem. I've tried logging out of both apps and then restarting but I still can't get them to connect. Any suggestions?
07-07-2020 15:33
07-07-2020 15:33
Have you resolved the issue?
