01-06-2016
21:55
16:59
01-06-2016
21:55
16:59
I use to be able to change but since the update I don't seem to have that option. It is stuck at 5,000 and I want to change it to 10,000 steps a day. I have checked and it is still at 5,000. I am running Windows 10.
Great to see you around @Daubernut. If you want to change your goal, you just need to do the following:
1. Click the gear icon in the lower left corner of the tile you wish to edit a goal for.
2. Write your preferred goal amount in the outlined box.
3. Click the “Save” button.
Let me know the outcome! ![]()
You are welcome @Daubernut. It is great to see that your inquiry has been resolved. If you need anything else do not hesitate in letting us know.
Happy stepping and good luck reaching your new goal. ![]()
What gear? What icon? Still unable to change my step goal.
Great to see you around @unknown100 and @waddinpd. The gear icon will appear at the moment of taking the arrow at the bottom of the tile (see attached image).
If you sync your trackers with a phone, tell me which phone you have so I can provide you the instructions to change your goal directly from it.
Hope to hear from you soon. ![]()
Best AnswerThis isn't working for me. When I click on the gear I'm given an option of deleting the tile. That's it.
