01-06-2016
		21:55
		16:59
		01-06-2016
		21:55
		16:59
I use to be able to change but since the update I don't seem to have that option. It is stuck at 5,000 and I want to change it to 10,000 steps a day. I have checked and it is still at 5,000. I am running Windows 10.
01-07-2016 04:00
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              01-07-2016 04:00
Great to see you around @Daubernut. If you want to change your goal, you just need to do the following:
1. Click the gear icon in the lower left corner of the tile you wish to edit a goal for.
2. Write your preferred goal amount in the outlined box.
3. Click the “Save” button.
Let me know the outcome!
01-07-2016 04:00
                              01-07-2016 04:00
01-07-2016 11:50
01-07-2016 11:50
Worked. Thank you so very very much. Now off to reach my goal.
01-07-2016 11:56
                              01-07-2016 11:56
You are welcome @Daubernut. It is great to see that your inquiry has been resolved. If you need anything else do not hesitate in letting us know.
Happy stepping and good luck reaching your new goal.
01-25-2016 15:20
01-25-2016 15:20
04-18-2016 15:25
04-18-2016 15:25
No gear icon appears in the bottom corner of the Step Goal tile on my dashboard.
 Best Answer07-22-2016 06:57
07-22-2016 06:57
What gear? What icon? Still unable to change my step goal.
 Best Answer07-24-2016 04:08
                              07-24-2016 04:08
Great to see you around @unknown100 and @waddinpd. The gear icon will appear at the moment of taking the arrow at the bottom of the tile (see attached image).
If you sync your trackers with a phone, tell me which phone you have so I can provide you the instructions to change your goal directly from it.
Hope to hear from you soon.
 Best Answer01-30-2017 02:48
01-30-2017 02:48
Didn't help because I can't find the tiles!!
 Best Answer10-02-2019 11:38
10-02-2019 11:38
this does not appear to work. All it does is ask me if I want to delete tile
 Best Answer05-17-2020 08:16
05-17-2020 08:16
This isn't working for me. When I click on the gear I'm given an option of deleting the tile. That's it.
