09-23-2019
13:51
16:59
09-23-2019
13:51
16:59
When trying to sync my Flex my phone states "No Device Found" WHY??? HELP!
09-23-2019 15:17
09-23-2019 15:17
I'm having the same problem..."no device found"
09-27-2019 06:29
09-27-2019 06:29
Thanks for your reply. Since I have no resolve and Fitbit doesn’t have a way to communicate with them directly, I have taken my Fitbit off!!
09-28-2019 22:49
09-28-2019 22:49
I have the same problem!! I've tried adding it on my iPhone, ipad,, laptop - NOTHING is working!! I've restarted my phone a gazillion times,, turned my Bluetooth on and off etc etc etc.
My fitbit is charged but nothing is working 😞
09-29-2019 05:46
09-29-2019 05:46
09-29-2019 17:57
09-29-2019 17:57
09-30-2019 09:48
09-30-2019 09:48
Lots of us Flex users are having the same issue, Fitbit have just offered me 25% off a new one, this one works fine, I suspect they are causing this issue.
09-30-2019 10:57
09-30-2019 10:57
Thanks so much for your tip. Sadly it didn't work 😞 I appreciate your help though!!
I am going to keep trying a few more times just in case!!
Best Answer09-30-2019 10:59
09-30-2019 10:59
I'm glad they offered you a discount!! I am not sure if I want to risk putting money in to another Fitbit 😞 Too bad though because I really thought it was helping me to stay active! Sad how a few dots have that much power! LOL
09-30-2019 11:31
09-30-2019 11:31
THANK YOU!!!! After trying several times IT WORKED!!!!
09-30-2019 15:57
09-30-2019 15:57
Best Answer09-30-2019 18:17
09-30-2019 18:17
Best Answer10-01-2019 09:59
10-01-2019 09:59
THANK YOU!! BUT AFTER 5 UNSUCCESSFUL TRIES, I DID THIS STEP ONE MORE TIME AND PUSHED THE PAPERCLIP IN HARDER AND HELD IT THERE FOR A FEW SECONDS. THEN I HAD TO CLOSE DOWN MY PHONE ALL THE WAY AND BRING IT BACK UP. THAT WORKED FOR ME!
Best Answer10-01-2019 11:27
10-01-2019 11:27
I had the same problem. Plugged my Fitbit in, used the paper clip reset and held it for a count of 10. Then restarted my iPhone and shut my Bluetooth off and then on and then it worked.
10-02-2019 12:21
10-02-2019 12:21
I've had the same issue for six weeks. Tried to sync it on another phone and still no luck. I know my fitbit is working as it vibrates when I've done my step goal. No solutions offered by fitbit support.
10-03-2019 19:04
10-03-2019 19:04
I have the same issue today when I just updated the Fitbit App on my iPhone. I keep on getting the "No Device Found" message after trying to synced my fitbit flex. I restarted my phone multiple times to no avail so I called the customer service just now, the guy was very helpful, so basically what you have to do first is to turn off your Bluetooth connectivity on your iPhone. Then you charge your fitbit device, and use a paper clip or any any kind of needle looking stick that is thin enough to poke that little tiny hole behind the fitbit charger to reset the device, press it for a full 4 seconds. Then turn your Bluetooth connectivity on your iPhone again and now you can synced back. Good luck!
10-04-2019 08:09
10-04-2019 08:09
Best Answer10-04-2019 08:51
10-04-2019 08:51
I removed the device and added it again and it seems to have worked, really disappointed that the trained trouble shooters at Fitbit didn't suggest this and told me my Fitbit was broken.
Best Answer10-04-2019 15:48
10-04-2019 15:48
Renee Jogger -- thanks, the paper clip is the correct solution for me! I got my Flex used and possibly it had some old settings. Resetting it in the charger fixed the problem immediately.
Best Answer01-05-2020 09:14
01-05-2020 09:14
Message on phone reads 'device not found'. Tried uninstalling more than once, still the same although did work for about one week then nothing. Can you help please.
Thanks
