two spaced lights alternating, what does it mean?
ANSWERED
When I tap it My wrist flex has a flashing pattern of 2 spaced lights alternating over one position with 2 spaced lights. E.g. lights in position 1 and 3 alternate with positions 2 and 4.
Any idea what this means?
55 REPLIES 55
Several different days my fitbit flex has has 2 flashing lights that change location why?
I don't know what it means but I do know how to stop it.  Tap it several times and the 5 lights will return.
No nothing changed
@CBrink thanks for joining us! Sounds like your Flex is stuck in activity mode. Please hold your finger close to the band, tap rapidly (about 5 taps shortly after each other) until it buzzes so it goes off activity mode. When double tapping off activity mode, you will see a spinning light pattern and then your actual step progress. Just like @nanaburg suggested. If that doesn't do it, then I recommend restarting your Flex:
  1. Plug your charging cable into a USB port on your computer or any UL-certified USB wall charger.
  2. Remove the pebble from the wristband and insert it into the charging cable.
  3. Insert a paperclip into the small pinhole on the back of the charger.
  4. Press on the pinhole for 3-4 seconds.
  5. Take your tracker out of the charger and insert it back into the wristband.
Keep me posted with the outcome! Smiley Happy
Mariam | Community Moderator, Fitbit
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Thanks
@CBrink You're welcome! Did it work? Do let me know, I'll be around. Smiley Happy Smiley Wink
Thanks I have been trying to learn how to set my flex in sleep mode
 Thanks for the help
Mine doesn't do the dimming, or seem to come out of "sleep mode" at all. I can keep trying the tapping over and over, and it still does the 2 alternating flashing lights.
@Tracifoster2017 you're very welcome! It's nice to see new faces in the community. Smiley Happy Smiley Wink Hope to see you around more often!
Thanks for taking a break from stepping to visit the community @cmullins05! Please note you need to rapidly tap your tracker in order to exit sleep mode. Hope this helps. If that doesn't do it, then I recommend a restart by doing the following:
Hope this helps. Keep me posted with the outcome! Smiley Wink
Apparently the flex will constantly toggle in and out of 'sleep mode' from vibrations it gets exposed to, like riding a bike.
It means that you put your flex into sleep mode and to get out of it tap rapidly until vibrates and shows 5 dots and you out of sleep mode
I would prefer it not fall into sleep mode going about my day. I get
exposed to some vibration at times.
@Gayboy & @stomper thanks for joining us! To exit sleep mode, just rapidly tap your F;ex until you feel it vibrate. What kind of vibration are you exposed at times, for example when riding your bike? Could you please give me more examples?
Looking forward to your new comments!
My Fitbit won't charge-- no lights, nothing.
after a few taps, I get the same 4 lights-- 2 separated by a space, and 2 more --that everyone is mentioning.
what to do? Is this the end of my Fitbit ?
I don't think my Flex has sleep mode.
All it does - when it is not charging.
Is show dots and somethimes more than one
Thank you!!!  Tapping my Flex 5 times rapidly fixed the 2 lights spaced out putting it back to all lights lighting up showing my steps progress.
