06-18-2017 23:33 - last edited on 08-20-2020 16:59 by MatthewFitbit
Hello anyone reading - if you had this problem I have a solution.
1. On the app tap account.
2. Tap '+ set up a device'
3. Select the fitbit you have and tap 'replace'. Go through all the steps.
4. Once done, you will be taken back to the dashboard.
Your accounts stats, friends and more will still be there.
I hope I helped you resolve your problem. Thanks!
06-19-2017 08:01
06-19-2017 08:01
@ZuneZone Welcome to the Fitbit family! Wow, thank you so much for sharing that awesome workaround that has helped you out in the past.
It makes sense as setting your tracker as a replacement device will reset its inner components (without erasing any previous data on your account, of course) resulting on the tracker fixed and working properly.
I'm pretty sure this will help other users as well! Thanks for your awesome help!
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
See you around!
09-07-2018 17:53
09-07-2018 17:53
09-13-2018 10:42
09-13-2018 10:42
Hello @Haleho, thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for letting us know about the troubleshooting steps you followed in order to fix this issue on your side. I'm sure these instructions will be very helpful for members of the Community facing the same situation so I would like to thank you for sharing them.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
08-21-2019 11:14
08-21-2019 11:14
Reset as instructed. Only shows calories burned. Still does show steps??
