03-11-2024
10:16
09:51
ManuFitbit
03-11-2024
10:16
09:51
ManuFitbit
Until the most recent iOS update, the Fitbit App on my iPhone 11 Pro would accurately track my distance using GPS when I manually started a run. It would continue to track even when I locked my phone screen. As of the iOS 17.4 update, GPS stops tracking through Fitbit when my screen is locked. I confirmed that my Fitbit location services are set to “always on,” but it’s still not working.
Anyone else have this issue or a solution?
Fitbit released an app update three days ago (version 4.13), but unfortunately it didn't address this issue. It has to be a software problem. I would be interested to know if anyone who hasnt updated their iPhone to ios 17.4 and uses the fitbit app on their phone to track walking/running is having this problem.
Just curious, did you also update your iPhone with ios 17.4?
05-31-2024 07:26
05-31-2024 07:26
I posted yesterday that this fix worked. Well, it was short lived. My walk last night had the same, bad result. No tracking (well .25 of 1.04 miles). Still an issue.
Bryan
05-31-2024 07:27
05-31-2024 07:27
Make sure it works twice! Mine worked the first time and then didn't the second day.
05-31-2024 07:46
05-31-2024 07:46
05-31-2024 13:43
05-31-2024 13:43
I have done this several times and it is still not working. I’m losing the will, but thanks.
Best Answer05-31-2024 14:14
05-31-2024 14:14
Hi everybody! Thank you all who confirmed that the instructions helped. I've informed our team that this didn't work for everybody! They'll be looking into this to work on a universal solution for everyone.
We appreciate your patience until this is done. I'll be updating the thread , should I receive further information.
Best Answer06-01-2024 10:02
06-01-2024 10:02
Hi Juan
I went for a walk this morning. My Fitbit is linked to Strava, but the link is no longer working. So I set the exercise on my Fitbit and on the Strava app. As you can see, the Fitbit app recorded the walk completely inaccurately. The first record has been pushed across from Strava app and the second is what Fitbit recorded. When will this be sorted out.
Best Answer06-02-2024 10:04
06-02-2024 10:04
Wow it’s been 3 months and Fitbit still hasn’t fixed this issue?? This makes half of the Fitbit tracker worthless. I would have expected this to be a high priority fix.
I foolishly thought the issue was with my old tracker not connecting properly and purchased a new Fitbit, only to discover the same exact problem. If I unlock my phone and let it take a second to refresh, it will record *that single point,* but if I leave my phone screen locked it won’t record anything until I unlock it again, and then it jumps to that spot. As others have said, I’ve been using this app for years with no issues. I’m ready to return this tracker and go purchase from another company, this is absurd.
06-02-2024 10:26
06-02-2024 10:26
Juan, sorry but nothing is fixed, the fitbit app does not register the gps teack properly, when i switch it on from phone it does not work anymore while it did for many years. To switch it on from fitbit, the gps signal is so bad, it tracks maybe 20% of the movement… i can keep on writing and explaining but something has changed. I use these functions for many years but since 3 weeks it stopped working. This is software related, not about settings or hardware.
Best Answer06-02-2024 17:50
06-02-2024 17:50
Best Answer07-17-2024 10:36
07-17-2024 10:36
Hi everybody ! Thank you for your messages and information.
Our Team informed me that the issue with the GPS should be solved with the new app update (just released v4.21)
Please update the app. Turn the phone off/on again.
Let us know over here if you are still having difficulties or it got solved for you .
