06-18-2019 08:08
06-18-2019 08:08
How exactly do I restart the Inspire HR?
06-19-2019 01:02
06-19-2019 01:02
The restart instructions for the Inspire HR are:
taken from: Help article: How do I restart my tracker?
06-19-2019 01:02
06-19-2019 01:02
11-03-2019 14:49 - edited 11-03-2019 14:49
When I restart my device (Inspire HR), I see the smile face, but it doesn't vibrate. Is that something I should be concerned about?
12-09-2019 18:56
12-09-2019 18:56
No. It's not a problem for me.
12-25-2019 16:17
12-25-2019 16:17
I have same. It’s not acceptable to have no vibration
12-25-2019 20:31
12-25-2019 20:31
@Lmbshaw - after the holidays when I have more time, I'm going to chat with customer service. They've been very responsive in the past, and so I'm going to do that, will let you know what they recommend, or work out.
Holiday Cheers to all!
Gerry
12-29-2019 12:38
12-29-2019 12:38
Unfortunately, this did not resolve the issue.
01-14-2020 17:47
01-14-2020 17:47
Absolutely worked! Thank you for step by step instructions. You're lifesaver! 🙂
01-20-2020 19:15
01-20-2020 19:15
When I try to restart my Inspire HR device, I don't see the smiley face. What does that mean? Does it have to be at 100% charge to work?
01-21-2020 05:44
01-21-2020 05:44
Hello Jan03855 - I think you need a reasonable charge to restart it, so charge it up.
Then do as SteveH says above. Make sure you continue pressing the side button, then it should work as he says.
01-23-2020 15:33
01-23-2020 15:33
I was gifted an Inspire HR with a clip charger, as opposed to a magnetic charger. Does anyone know if it MUST be attached to a magnetic charger in order to reset? I haven’t been able to reset the IHR at all. I’m curious to see if buying a new magnetic charger would be worth my time or if I’m encountering a different problem all together.
03-11-2020 13:29
03-11-2020 13:29
I saw smiling face icon but it didnt vibrate. What does it mean.
03-11-2020 13:39 - last edited on 07-21-2021 04:14 by JuanJoFitbit
I tried to restart my inspire HR but it doesn't seem to do anything. Not restarting that's for sure.
It is not syncing the data to my phone. I am getting notifications and the dashboard on the computer shows the data but it won't show on the phone - this happened after the battery died and hasn't worked right since. I just got this about 4 weeks ago!
When I push the button it vibrates right away then hold for 5 seconds it doesn't do anything else, just keeps the screen on till I let go.
Help?
Moderator edit: merged reply
03-11-2020 16:15 - last edited on 07-21-2021 04:15 by JuanJoFitbit
Same here! Help!!
Mine is brand new. Can’t get device paired. Fully charged. No display when I tap - only with the display button. Only displays scrolling www.Fitbit.com/setup. App sees the device but won’t pair. Doesn’t seem to restart. Doesn’t vibrate.
HELP
03-12-2020 03:53
03-12-2020 03:53
Hello everyone, the other day I finally had time to do a chat with the Customer Support folks, and they were very helpful for me. I've also dealt with issues with a previous device using their email customer support. I'd recommend either to anyone having any issues.
I know it took me a while to get used to the touch screen of the HR Inspire.
03-17-2020 07:59
03-17-2020 07:59
I'm having the same issue where it won't restart. It's fully charged. I push and hold the button for 5 seconds, it vibrates as soon as I push the button, screen lights up and shows me the battery, then goes black after a few seconds. No smiley face, no vibration.
Anyone got an answer from helpdesk yet on this issue?
03-29-2020 09:55 - last edited on 07-21-2021 04:16 by JuanJoFitbit
Me too! Soooo frustrating.
Same issue here. Time to return I think!
03-29-2020 12:43 - last edited on 06-18-2020 18:53 by LiliyaFitbit
I'm having the same issue with the restart, and mine won't hold a charge. It's less than 1 year old. I charged it to 100% last night, it was dead again this morning. Charged it again to 89%, went to Lowes and it was dead when I got home. Charged it AGAIN to 76%, it's dropped 20% charge in 15 minutes. I tried restarting it, it didn't give me a smiley face or vibrate. I'm getting pretty frustrated with it.
Moderator edit: format
03-29-2020 12:54
03-29-2020 12:54
03-30-2020 12:54
03-30-2020 12:54
I was finally able to get through to Fitbit customer service. He had me hold the button until it restarted not just the 5 seconds they say to. Took a good 10-15 seconds. So for those having issues with theirs not restarting give it a try. I don't know if he did anything on his end but mine finally restarted after not being able to get it to for months.
