After the new OS update, I am unable to save my custom stats. I like to view particular things when I run, bike, etc. I work out 2-4 times a day, and it is frustrating to have to reset these before every single exercise. Anyone know what is going on with it?
06-05-2018
06:46
13:45
06-05-2018
06:46
13:45
@jwebb72 I hope you're doing well! Thank you for downloading the new firmware version for Ionic. I'm very glad to hear that this situation seems to be sorted now. Please update me in a couple of days with the final results!
@bmw54 @Derek311 Thanks for your replies! Yesterday, new Ionic's firmware (OS 2.1.1 or version 32.10.20) was released. As usual, this is a progressive roll out. If you haven't received it already, you should in the following days. This update includes some bug fixes so please give it a try! Check this post for more details about it.
Hope this helps. Please let me know the results! ![]()
Having same issue and I have the latest firmware update. Got the ionic last week. Hoping this issue is fixed quickly. It gets frustrating.
07:26
13:45
06-05-2018
07:26
13:45
@Naccarek Welcome to the Fitbit Community! Thanks for reporting that you are also experiencing this situation with Ionic custom stats.
I contacted you via PM. Please keep an eye on Community inbox!
See you around! ![]()
Downloaded the latest firmware and my custom states are still reseting after syncing the fitbit.
06:23
13:45
06-07-2018
06:23
13:45
@trekkerdean Thanks for your reply and for updating Ionic to its latest firmware version.
Just as @jwebb72 kindly suggested, please perform a restart on your watch. Then, check if the custom stats are saving. This should help you out!
Let me know how it goes! ![]()
Happy to report that the exercise custom stats are still sticking since the update. Unfortunately, the automatic laps (exercise cues) are still reverting back to .5 miles after syncing. Before, the workaround was to set on the Fitbit dashboard but even that doesn't work now. Strangely, the Fitbit Android app exercise cues are sticking but not on the watch or the Fitbit dashboard. Hope this helps.
I've updated and installed and reinstalled and reset everything and my custom stats STILL don't stick AND my app notifications won't load. Suggestions beyond what I've already tried ad nauseam?
Best AnswerI have given the watch a restart and the custom stats are still not holding.
Tempted to do a factory reset and see how that goes.
Best AnswerI have done a factory reset of the phone to avail. Want to check that I am using the correct version of the fitbit ionic software version 27.32.10.20.
Best AnswerAn interesting side note - the issue *appears* to be exercise specific. That is to say, my custom stats for swimming are sticky, but all other exercises I have attempted to customize (Run, Golf & Walk) are NOT sticky. They all reset after I sync.
Updated as you suggested and still no luck. Very frustrating and disappointing. When I walk or do the elliptical I want HR on the top and steps on the bottom and have to reset them every single time. It was never like that before the OS 2 update and three months later you still haven't fixed it.
Hello
Did you do a particular manipulation?
For me ionic does not save stats (running)
