01-23-2018
19:50
12:17
EdsonFitbit
01-23-2018
19:50
12:17
EdsonFitbit
I reset my ionic
however, I got a Red X and say "Data not cleared Sync & try again"
But I cant do anything in my Ionic, no response when I push all the button
What should I do?
Fitbit Ionic error message “Data not cleared. Sync and try again”
I found another thread... Here is the link: https://community.fitbit.com/t5/Ionic/Data-not-cleared-Sync-amp-try-again/td-p/2220514
Best AnswerFitbit Ionic error message “Data not cleared. Sync and try again”
I had the same problem with the red X and data not cleared message... after trying all the solutions listed and several other attempts I found the solution that worked for me & my Ionic... I contacted Support via messaging... A wonderful person, 'Loren' was very helpful and polite in giving me easy to follow instructions on how to reconnect my ionic fitbit and get moving once more! It was done in about 10 to 15 minutes... not counting finally getting the firmware download which took a bit longer. Well worth the time as I had spent most of the day trying to do it myself.
Best AnswerSo what's the solution??
Best AnswerSeriously - what do you do?
Best AnswerThanks! This worked for me.
Best AnswerThis worked for me. Had to resurrect the watch after it failed an update to the tracker firmware.
Best AnswerI get this error message at least once every couple of weeks.....the first time it happened I was really stuck. Now it literally takes me less than 10 minutes to reset.
Step 1....turn off the blue tooth on your phone
Step 2....go into your Fit bit app and unpair your phone and your device....usually I just hit the button for add a new device and it asks me if I wish to replace my existing fitbit and I answer yes.
Step 3.....phone then asks if it can turn blue tooth on to which you answer yes
Step 4.....it then searches for your device and you get once it finds it it asks you for the 4 digit code that is now displayed on Fit Bit screen
Step 5...... allow the system to reconnect with your Fit Bit device...takes about 10 minutes to upload everything and Voila!
or you can check in your Fitbit app if their is an update for your band. If so then update your band.
Best AnswerThis solution does not work.
