02-12-2018 15:18
02-12-2018 15:18
Since Last Friday I have frequently been wearing my Ionic. Despite that, my heart rate is not being tracked and only shows me “- -“ whenever I look at it. Similarly, on the app, no data is being registered and it only shows my resting heart rate for each day.
as regards the sleep tracker, each nights data only shows the length of the sleep and restlessness but no data as regards heart rate
I have tried cleaning the sensor on the back of the ionic, restarting the Fitbit and other things but I haven’t a clue... anyone? Would be appreciated.
Best Answer02-16-2018 05:27 - edited 05-19-2025 10:45
Welcome to the Fitbit Community @SamTowle! Thanks for already cleaning the sensors and restarting your tracker.
As you may know, your tracker can have difficulty finding a signal, typically due to the tracker's fit. For example, wearing your band tightly may constrict blood flow in your wrist and affect the signal. We recommend experimenting with how high you place the tracker on your wrist. When you're not exercising, wearing the tracker just above the wrist bone--as you would a watch--typically works fine. However, moving the tracker up a couple inches can be helpful during high-intensity exercises or exercises that cause you to bend your wrist frequently. If you haven't already done so, please review our recommendations for wear and other tips shared by @SantiFitbit.
If you're wearing the tracker correctly and the heart rate setting isn't turned off, try changing the setting (either Auto to On or On to Auto) and then syncing your tracker. The change won't take affect until you sync. If heart rate doesn't seem to start tracking correctly, try restarting your Ionic.
Note that on Fitbit Ionic, the heart-rate value appears gray if your watch is searching for a stronger reading.
In addition, I think it's great that you update the Fitbit app to the latest version (iOS and Android). I always recommend keeping both the tracker and the Fitbit app up to date with the latest versions.
Try the recommendations and let me know the outcome!
