07-17-2018
12:57
17:12
SantiR
07-17-2018
12:57
17:12
SantiR
Factory reset applied as per support request. Stuck in a loop as shown above the last hour. @fitbitsupport how far do I have to go to prove the problem is with the FITBIT ?
Moderator Edit: Updated Subject for Clarity
03-21-2019 00:00
03-21-2019 00:00
Was your issue resolved? I am
experiencing the same
problem. It won’t reset. The Fitbit logo just keeps appearing then disappearing.
03-21-2019 03:05
03-21-2019 03:05
03-22-2019 15:59 - edited 03-22-2019 16:00
I had the exact same problem problem. My fit bit was flashing on and off with the logo so I let it die and sit on my desk for 2 weeks. Tonight I temp to do charge it and got a flashing logo again spent about 45 minutes pressing different configurations of all the buttons to include the standard factory reset and the standard reset options. I'm currently letting it charge. It did Flash on and get stuck on the logo but I let it sit there for about 10 minutes then the watch vibrated in my clock screen appeared. Bottom line it's a firmware issue withe fitbit.
03-23-2019 09:23
03-23-2019 09:23
Glad your back working @Drew_Chiles ii could be that the firmware had not started up correctly, or that it is a hardware issue. If it was a true firmware issue it would be affecting all units.
Best Answer03-26-2019 04:06
03-26-2019 04:06
Hi there, I saw your reply to MuffinTumble for the same issue I am having...that is, my Ionic is stuck on logo screen. It sounds like this requires opening a case with customer support. Can you help me do that, as well? Or is this something I can do on my own? Thanks in advance!
Best Answer03-26-2019 06:22
03-26-2019 06:22
03-26-2019 06:47
03-26-2019 06:47
03-26-2019 09:36
03-26-2019 09:36
That's not true Rich. It's most likely firmware + clock face - or some other bug. This started happening to me as well & I can get the fitbit online but once it forces a tracker update the watch is bricked once again. Support told me to buy a new one since I'm 2 months over the 1 year warranty period.
I loved my fitbit - and now I'm stuck with a lemon.
03-26-2019 12:50
03-26-2019 12:50
I just contacted customer support. While my watch came back up, it failed very ither day and just shuts off.i plug it in and it says it is 100% charged, take it off and it turns off. My new one should be here this week. But I stand firm that I believe it is a firmware issue.
03-26-2019 12:54
04-23-2019 06:06 - edited 04-23-2019 06:06
Mine is doing the same thing, stuck on Logo Screen, asking to reset, but won’t reset. I’ve been trying to get it to work for two days. Ughhhh, I love my watch and miss it.
04-23-2019 12:06
04-23-2019 12:06
@LynnSmith have you heard back from support when you contacted them? The contact info may be found in the top right corner, under the help link below, the help in the app, or a quick google.
04-24-2019 15:48
04-24-2019 15:48
Mine did the same thing last week, just got it 4 months ago so they are sending me a new unit. This sounds like a very significant fatal design and/or build issue with the deice or the OS. Based on all of the posts with the same issue I think they need to scrap this model like they scrapped the Blaze. Had issues with that as well but made it past the warranty so I was out of luck.
08-11-2019 20:48
08-11-2019 20:48
Yes I am having the same issue. It will not reset using the 3 button method. I have tried. The moment I let go of the buttons the logo pops back up. @Rich_Laue
My Ionic is older than 4 months and probably out of warranty. Am I boned if this is not an issue that will fix it?
08-21-2019 09:25
08-21-2019 09:25
Hi Rich_Laue,
quick question on the 3 button method. After screen flashes, how long do you have to wait until it goes to blank screen? I held it for about 5 flashes, but still no blank screen.
Best Answer11-07-2019 02:30
11-07-2019 02:30
I have the same issue, did you managed to resolve it?
Best Answer11-14-2019 23:22
11-14-2019 23:22
Hi,
I seem to be having a similar problem with my ionic. Today it just decided to stop working and has the logo frozen on the screen.
I’ve tried all suggestions in this feed and watched videos etc and still can’t getting working.
Did anyone manage to fix their problem? If so, could u tell me how please?
Hate not having my watch!!
Thanks in advance!
Best Answer12-19-2019 03:33
12-19-2019 03:33
Have run into the same issue, removed the device from the app & for some reason unable to do the reset of the fitbit ionic... it looks like the ionic is becoming the most unreliable device of Fitbit
12-19-2019 05:41
12-19-2019 05:41
Allow the battery to drain off, then try the reset...it works for me
12-19-2019 05:43
12-19-2019 05:43
interesting I was thinking about doing that too 🙂
