07-17-2018
12:57
17:12
SantiR
07-17-2018
12:57
17:12
SantiR
Factory reset applied as per support request. Stuck in a loop as shown above the last hour. @fitbitsupport how far do I have to go to prove the problem is with the FITBIT ?
Moderator Edit: Updated Subject for Clarity
12-19-2019 07:02
12-19-2019 07:02
Have you tried a restart by holding in the left and lower right buttons.
12-19-2019 07:17
12-19-2019 07:17
Yes it keeps coming back to the same loop screen.
But even when I was trying the restart didnt get the vibrate to indicate the reboot
12-31-2019 22:31
12-31-2019 22:31
I have the same issue with my ionic. Tried the 3 button restart, but it doesn't vibrate or reset or anything.
What is the next step?
01-02-2020 03:38
01-02-2020 03:38
To do Factory Reset process properly:
(I called Fitbit they gave me technical method. )
1. Hold all 3 ionic buttons for 15 secs
(* tip count 15 secs)
2. After 15 secs , release lower right button.( Keep other 2 buttons pressed.)
3. Holding the other 2 buttons. Only Until The ionic vibrates. Then now let go of all buttons.
4. screen should go fully black.
5. At this point Support said wait 2 mins while ionic clears and resets data. (it could take longer) . Get a cuppa tea! it you come back and its still blank just press left button to turn it on.
6. The follow normal procedure to install updates and sync with your phone app.
END
01-04-2020 16:32
01-04-2020 16:32
Thanks for your response TangoWhiskey.
UPDATE - the fix you suggested worked, for a few days. Now the watchface has become non-responsive; I let it fully charge overnight and it's still black, no fitbit logo or anything even when I hold all three buttons for over 15 seconds.
01-04-2020 20:44
01-04-2020 20:44
doesnt vibrate
01-14-2020 13:33
01-14-2020 13:33
I have the same issue. Just the fitbit logo on the screen.
This is my 3rd Ionic and have been told by fitbit i need a new watch. The one i have on is the 3rd replacement and arrived May2019 but I have found out the warranty is from the original watch.
So basically this one lasted 7months and failed again.
They said as a good will they will give me 25% off a new one.
So you can see my issue with the Ionic not being reliable.
3 Ionics 3 different faults.
1st failed to hold charge
2nd failed to charge
3rd has just failed and got the fitbit logo on it.
NOT A HAPPY CUSTOMER
I had 2x Surge prior which failed to hence my upgrade with the 25% off to the Ionic.
Bad move
01-14-2020
15:09
10:07
AlvaroFitbit
01-14-2020
15:09
10:07
AlvaroFitbit
Oh man. That stinks! Very unfortunate. I moved to the Fitbit Versa 2 and so far, so good. But I would be lying if I said I wasn’t worried about how long it will last. Can’t believe Fitbit won’t do the right thing given your history. Bummer.
Moderator Edit: Personal info removed
01-16-2020 11:12
01-16-2020 11:12
So did everyone finally realize that the Over the Air updates fitbit is sending is what is causing these ionics to stop working, but wait... there is more... this OTA update only happens after your warranty has expired. How convenient.
-_-
01-30-2020 22:08
01-30-2020 22:08
I had the same issue and finally got mine to reset by doing the same steps while it was plugged into my computer.
02-05-2020 06:53
02-05-2020 06:53
Fitbit Ionic, logo stuck on the screen and can't get past it. How do I fix this ?
02-29-2020 22:04
02-29-2020 22:04
The logo has been stuck on my phone for days. I tried the 3 button button pushing and reloaded the app. Nothing works.
03-01-2020 04:17
03-01-2020 04:17
Mine did the same. . stuck for months. Consider the Fitbit fried if you've attempted that & it doesn't work.
03-01-2020 06:17
03-01-2020 06:17
having the same issue. Got this watch only in June 2019. contacted Fitbit and they have opened a ticket for fix. Hopefully they will respond and get me fixed soon. Will keep you all posted.
03-01-2020 17:44
03-01-2020 17:44
ok, it works now!!
Here is what i did.
contacted Tech Support.
They told me to do the 3 button reset process - Reproducing the steps below. - some more to do AFTER this, see bottom of message..
Before we can move forward to the next step, we just need to make sure that we haven't missed any troubleshooting steps. Please try the factory reset:
After doing this for God knows how many times, i got an error message (like - Unable to Sync).
Tech told me to now treat it as NEW ionic.
So, in my phone, unpaired the current Ionic and tried as if i am repairing a NEW one.
After a few missteps - going back and forward,
IT WORKED!!!
hope you will be able to get it back again. GOOD LUCK!!
03-01-2020
18:16
10:08
AlvaroFitbit
03-01-2020
18:16
10:08
AlvaroFitbit
Thank you so much!!! I really appreciate you sharing!
03-01-2020 19:40
03-01-2020 19:40
im sorry but even the best answer doesnt work for me. It started happening when i forgot to recharge it before going to bed and when i woke up, it was showing 0%. After that, I charged it the whole morning and when i picked it up, it's just showing the fitbit logo and does not respond
03-09-2020 16:09
03-09-2020 16:09
Mine does the same. Only the icon is on, and i can't do anything else.
03-09-2020 16:13
03-09-2020 16:13
Mine does the same, did you get a answer?
05-31-2020 14:06
05-31-2020 14:06
My Ionic is doing the same.
