04-11-2018 11:14
04-11-2018 11:14
I'm being prompted with the message "Not Charging. Not Enough Power Detected from this Source." I've tried different (USB) power outlets and chargers, but still continues to receive the same message. I started experiencing this issue after upgrading to the latest firmware. I did hard and soft reset (left button + lower right button) several times, but to no avail. In reality, it appears to be charging. Is this a bug in the new OS? I'd like to get rid of this annoying message. Please help. I'm pulling my hair...
11-13-2018 12:11
11-13-2018 12:11
Hey @spiketrain, I hope you are doin' great! If you are getting also this error, "Not Charging. Not Enough Power Detected from this Source." I'd like you to try the tips in this help article: Why isn't my battery charging? And let me know how it goes!
@Telico, I appreciate you have taken the time to try to fix this issue with your Ionic. I have escalated your case for you to get further assistance so please keep an eye on your inbox.
I'll be around!
11-13-2018 14:42
11-13-2018 14:42
Thanks for moderator support - very grateful.
I fixed the problem yesterday however by simply purchasing 2 x new charger cables from Amazon. They're third party copies - but they work.
FYI - my single Fitbit cable was never subjected to any duress that I can remember and exhibited this issue nonetheless - it did charge the watch, but did it slowly and temperamentally.
So - easy and cheap fix in the end - but a little disappointed in the quality (functionality) of the Fitbit branded cable that came in the box.... normally it's the other way around - IE the copy cables are never as good as the originals.... not so this time it seems.
11-14-2018 06:09
11-14-2018 06:09
Thanks for your reply @spiketrain! I appreciate you have taken the time to get new charging cables. Sounds good that they are charging your Ionic, even though, not as you have expected. Let me ask you something, do you like me to escalate your case with our Support team for them to further assist you?
Keep me posted!
11-14-2018 09:39
11-14-2018 09:39
Mine charges very well with the charger plugged into my docking station. My Surface Pro has exactly one USB port, so if I have to plug the charger in there, I do without my mouse until it's charged. The docking station is a hardwired affair, so probably that's why it charges properly. Yes, wall plugs are not always so good. You should know (as I learned this morning) that if you're going to download music or podcasts on to the Ionic, you do have to plug it directly into the computer.
11-15-2018 10:19
11-15-2018 10:19
Thanks for the offer. I'm okay with the new cables so I'll just stick with that.
All the best
11-16-2018 12:20
11-16-2018 12:20
Thanks for getting back to us @Purrstachio and @spiketrain! I appreciate the information you have shared with us.
I recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your device.
Let me know if you have any questions.
11-24-2018 08:39
11-24-2018 08:39
Hey Fitbit
I am having the same problem on my ionic..changed the cables and power sources ..bit frustrated by it all I love my watch but need the glitch sorted...I can only presume its a software issue?
any help would be appreciated
11-24-2018 17:57
11-24-2018 17:57
I have had that problem if the contact area on the back of t he Ionic was wet or dirty.
11-25-2018 09:51 - edited 11-25-2018 09:53
Every now and than you have to gently clean the contacts of the cable and watch a pencil eraser or toothpick works great. The key word is gently!
11-27-2018 08:13
11-27-2018 08:13
11-27-2018 08:16
11-27-2018 08:16
Hi I have tried all the suggested fixes and it is still not charging properly I have even bought a new lead
any help would be appreciated I think its still under warranty
I look forward to hearing from you
A loyal fitbit customer
11-28-2018 10:39
11-28-2018 10:39
Thank you for trying all the suggested troubleshoot steps @abbas73. I´ll be glad to continue assisting you.
I got in touch with our Support Team and they have informed me that they are already helping you.
Please let me know how it goes.
12-03-2018 20:07
12-03-2018 20:07
I have a brand new Versa, just opened it today and I am having the same problem. The message and vibrations just won’t go away. The Versa is now charged 100% even though it keeps vibrations going with message.
12-04-2018 16:20
12-04-2018 16:20
@whosails It's great to see you in the Fitbit Community.
I'm sorry to hear that you are experiencing difficulties to charge your Fitbit Versa. Please be so kind to perform a restart to your device by following these steps. Then, follow our guide to charge it.
If you are still experiencing difficulties, please let me know.
12-17-2018 01:37
12-17-2018 01:37
I too am getting this message and all suggestions are to no avail .Even bought new cable .I would appreciate some help please .
12-17-2018 01:38
12-17-2018 01:38
12-17-2018 07:41 - edited 12-17-2018 07:42
It only works if I plug it into my IPad Pro. That leaves me with only one port to backup my computer or access my photography.
12-17-2018 07:43
12-17-2018 07:43
Try plugging the cable into a iPhone plug the cable needs more power that sorted mine out
12-17-2018 13:53
12-17-2018 13:53
12-17-2018 14:21
12-17-2018 14:21
This happens to me occasionally. Usually unplugging and replugging in the power brick/usb fixes the issue.
