11-05-2019
12:59
07:09
CindyMFitbit
11-05-2019
12:59
07:09
CindyMFitbit
I have done every reset and option available to us through the communities, and my Ionic will not sync. Very frustrating.
Best AnswerOpen the Fitbit App. Tap the watch's tile (the picture of your Ionic on the top right corner of the app). Under "Sync" you will find "Sync Now". Tap it to start a sync. official website
Best AnswerWonder of wonders... I was having the same issue, especially if I let my watch go completely dead before recharge. Sometimes the time would come up wrong. Attempts to connect and sync were not working... problem was I am using VPN through a third party. So my location bounces around the globe from anyone looking in.. turn it off if you have it and it should start working. Make sure your GPS location is turned on either on your phone or computer whatever you are using. Good luck...
P.S. I hate the fact that you have to hunt for a **ahem**ed answer to a problem. Staff at Fitbit are useless.
Best AnswerMine has had problems syncing for some time. It seems to sync only when it wants to. Sometimes once or twice a day sometimes once in 2-3 days. I do not have it set to the sync all day option. When I try to sync it with my phone it says "no device found". I will check it several hours later or the next day and it has synced at a time long after I manually tried to sync it. When I try to sync it with my laptop it merely tells me when it was previously synced. It always messages my phone when the battery is low so it doesnt sound like a bluetooth issue. I have tried all the troubleshooting steps like switching off/on options, unpairing/pairing but they do nothing. This is my third Ionic - the first 2 were replaced under warranty. Looks like I'm gonna need a 4th.
Thanks for addressing this topic. I was looking for the information regarding the same tellgardenfresh.
I have the same issue. Don’t realise Ionic has disconnected til weekly stats show no activity. I try to sync but app can’t find tracker when it’s right next to it and charged. Follow all the suggested steps to sync/connect. Doesn’t work but may find later it has, although rarely. Has a mind of its own.
22:40
07:12
CindyMFitbit
10-24-2021
22:40
07:12
CindyMFitbit
Moderator Edit: Promotional info removed
07:12
07:02
10-25-2021
07:12
07:02
Hi everyone. Welcome to the Community Forums @Mark7166.
I appreciate your findings and workaround, it's great to hear that it worked for you, and I hope this is helpful for any other user.
Have a nice day.
20:47
09:46
AndreaFitbit
11-01-2021
20:47
09:46
AndreaFitbit
I will check it several hours later or the next day and it has synced at a time long after I manually tried to sync it. When I try to sync it with my laptop it merely tells me when it was previously synced. It always messages my phone when the battery is low so it doesnt sound like a bluetooth issue. Prepaid Card Status
Moderator edit: format.
Best AnswerClean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device? The USB port or outlet is faulty. Try a different USB port or a UL-certified wall charger. ... Check the alignment and try reconnecting your device to the charging cable.
04:30
15:34
EdsonFitbit
03-02-2022
04:30
15:34
EdsonFitbit
If you can usually sync but your Fitbit suddenly refuses to work, it's usually the result of a problem with your wireless connection, so toggling your device's Bluetooth can help. Performing a reset on the Fitbit or the device you're syncing with can also resolve a lot of common issues.
15:35
07:02
03-07-2022
15:35
07:02
Hello everybody, thank you for visiting the Fitbit Community.
Currently, there is a voluntary Safety Recall of Fitbit Ionic Smartwatches.
For more information, please visit this thread.
Have a nice day.
19:42
07:02
08-03-2022
19:42
07:02
@Bernardo859 Thank you for visiting the Fitbit Community.
As mentioned before, there is a voluntary Safety Recall of Fitbit Ionic Smartwatches.
For more information, please visit our webpage at help.fitbit.com/ionic.
I am going to close this thread to keep the Community organized.
Have a nice day.
