09-29-2017
11:33
14:09
MattFitbit
09-29-2017
11:33
14:09
MattFitbit
Update: The issue resulting in syncing trouble for Ionic users has been resolved. If you're still having trouble with syncing, please check the steps in this article.
Good morning Fitbit Ionic users! Thanks for flagging the syncing issue with Ionic. Our engineering team became aware of an issue that affects syncing for some Ionic users. We are making progress on a retroactive fix for this and look forward to resolving this as soon as possible.
If you'd rather not wait for the system updates, you can use the following workaround:
For those of you who don't have time to try the workaround, rest assured that our team will fix this issue.
Don't let this bump in the road get in the way of reaching your health goals for the day! I will keep this thread updated with the latest.
Appreciate your patience, everyone!
10-03-2017 22:09
10-03-2017 22:09
I have the opposite issue. No problem with iPhone and ionic. But refuses to sync with PC
10-04-2017 00:28
10-04-2017 00:28
10-04-2017 02:52
10-04-2017 02:52
So I just bought the new Ionic and I cannot add this device to my app (previous Charge 2 and Blaze user). Every time I try to add the device it gets to the part where I select Ionic, press the " Set up your Fitbit Ionic" and then it just returns to the app where I started the process.
WTF?!?!?
This is a horrible customer experience. Don't release a product if the user cannot use the product.
Fix this ASAP - this was not an inexpensive item.
10-04-2017 03:00
10-04-2017 03:00
@Little27Bit wrote:So I just bought the new Ionic and I cannot add this device to my app (previous Charge 2 and Blaze user). Every time I try to add the device it gets to the part where I select Ionic, press the " Set up your Fitbit Ionic" and then it just returns to the app where I started the process.
WTF?!?!?
Uninstall and reinstall the app.
Best Answer10-04-2017 03:54
10-04-2017 03:54
10-04-2017 05:08
10-04-2017 05:08
I have updated to firmware 27.30.3.2 and now synchronisation works fine on my Mate 9.
There is hope!
10-04-2017 05:10
10-04-2017 05:10
I'm still having the exact same issues. Mine is on the latest version 27.25.16.7
Sync works for maybe 30 minutes, and after that it gets stuck on "looking for ionic", or "Bluetooth issue reset bluetooth"
I'm constantly restarting ionic, unpairing, repairing, going back to factory settings to get it to sync. I've tried on three different phones with the same issue each time.
After unpairing, when trying to re-pair it is very temperamental as to whether the phone will actually find the ionic or not. I usually have to try set up about 5 - 6 times before it finds the device and prompts me to enter the 4 digits.
Best Answer10-04-2017 05:17 - edited 10-04-2017 05:18
firmware 27.30.3.2
Is that the normal firmware or development?
Best Answer10-04-2017 05:20 - edited 10-04-2017 05:20
@Jorkal wrote:
firmware 27.30.3.2
That's developement firmware. It looks like Fitbit found out what was wrong and corrected it. So just wait for the next official firmware update and you should be fine.
Best Answer10-04-2017 06:02
10-04-2017 06:02
I have firmware version 25.16.7 but I am not having any issues
Best Answer10-04-2017 06:17
10-04-2017 06:17
I have to correct myself. Although the IOS App shows version 25.16.7 the online dashboard shows version 27.25.16.7. Since I am not having any issues I am not sure it matters but figured I would let everyone else know in case they had a different version and were having issues.
Best Answer10-04-2017 06:35
10-04-2017 06:35
Best Answer10-04-2017 06:38
10-04-2017 06:38
Best Answer10-04-2017 06:45
10-04-2017 06:45
Use this link https://help.fitbit.com/articles/en_US/Help_article/1871 to see how to update firmware.
10-04-2017 07:08
10-04-2017 07:08
I think it's Android issue first and foremost. I connected my Ionic to iPhone 6s yesterday, and the sync worked perfectly fine. On Android, however, depending on what phone you got (there's a tremendous fragmentation in terms of Bluetooth stack and its behavior) sync either won't work at all, or will be extremely flaky (something I'm observing on Essential PH-1 with Android 7.1.1 and September security patches).
Best Answer10-04-2017 07:10 - edited 10-04-2017 07:37
Does the developer firmware address two other issues I noticed (maybe specific to Android or my particular phone):
I'm on Essential PH-1, Android 7.1.1 with September patches. Ionic firmware is 27.25.16.7.
Best Answer10-04-2017 07:13 - edited 10-04-2017 07:13
Actually, my understanding is that to get newer/beta firmware, you need to register to become Fitbit OS developer:
Best Answer10-04-2017 07:24
10-04-2017 07:24
My Ionic sync flawless with iPhone, the Macbook connect with the Ionic (after a stopped bluetooth of the iPhone of course) but get an error; unknown error try again.
Best Answer10-04-2017 07:33
10-04-2017 07:33
Yes, Apple's Bluetooth implementation in many respects way ahead of Android, and it's a single vendor. Hence, it's no surprise sync would better on iPhone than Android phones. I haven't tried MacOS or Windows 10 apps at all. So, can't say much about that.
Best Answer10-04-2017 07:47
10-04-2017 07:47
I did try it on my iPhone 6s last night after the trouble with my new android phone (Huawei P10 Plus), and I couldn't even get it past the first step (ie couldn't find my tracker to enter the 4 digits)
I eventually got it connect to the P10, but having constant sync issues.
I have now connected it to my works mobile (galaxy A3 I think), and so far it's working but not holding my breath.
I might try it on the iPhone again when I get home from work.
