11-19-2017
02:37
12:54
MattFitbit
11-19-2017
02:37
12:54
MattFitbit
I am locked out of my ionic. It is saying to unlock with my phone however I have tried to change my pin in the iPhone app but after the process is complete I get a message saying “change pin failed”
its extreamly frustrating
Moderator edit: edited title for clarity
Hi same thing happened to. I tried all the suggestions, which didn't work .So as a last resort I uninstalled the app and then reinstalled it and everything is all good 😊.
Hi
Ive taken the steps to change pin but I’m the end it comes up saying unexpected error please try again later..
This has happened over the last few days..
A warm welcome to the Community @SunsetRunner and @RachelChar! Thanks for uninstalling the app.
Usually this happens when you've entered an incorrect PIN code 10 times, you will be prompted to unlock your Fitbit watch with your paired phone.
To change your pin, open the Fitbit app dashboard and tap the Account icon.
If you are using an iOS device, you will want to select the Device Lock setting. If you are using Android you will want to select Pin Lock. There, you should be guided to use your current pin and set up a new one.
You can find more information about it by checking this article.
Best AnswerI don't know about others, but this bug did not happen to me because of entering the wrong pin 10 times. It had to do with trying to allow payments and changing the pin method from fingerprint to number entry. Whatever causes it should have been corrected by Fitbit by now and I'm disappointed it is still occurring.
Best AnswerHi, I have tried everything to unlock the pin but I kept letting a failed message. I did everything before I uncynces the device from the app.. now i cant sync it again as the new code I need wo t show up.. just the unlock from phone message.. can someone help?
Thanks
Best AnswerI have an Ionic that is locked and says to use my phone to unlock. I changed phones and it won't connect to my new phone (actually old one). The time is wrong and I can't sync. When it send the code to the Ionic it won't let me see it because it is locked......HELP!!
Best AnswerThis doesnt work and neither do any of the solutions. Ive tried reinstalling, reseting, disabling fingerprint on my phone, all multiple times. This device is supposed to be compareable to the iPhone yet it is super bugy, years after launch. This is ridiculous.
Best AnswerI have a similar issue but my Ionic is uninstalled from my phone, I reinstalled it but it's stuck on the Unlock with your Phone screen when it tries to pull up the PIN and I'm afraid I'll have to get me a new watch
Best AnswerHello I was wondering if you could help me my fitbit versa is saying unlock with phone but when it comes to the pin part I can't see it as it says unlock with phone
Best AnswerI am having the same problem. I have tried several times its not working
Any help would be appreciated
Thanks
Best AnswerI followed these instructions on my Samsung Android S7 but still get this error message that says "Error connecting to Ionic" This despite that I have no problems having the Ionic sync with my S7 Fitbit app just before this. Anyone have any ideas?
Best AnswerI have the same problem, did you manage to get it fixed?
