01-13-2014 17:57
01-13-2014 17:57
I had Zumba class Thursday, Hula Hooping class Friday, rode my bike on Saturday, climbed stairs for 30 minutes on Sunday, counted calories all week and still can't lose weight.
I'm so frustrated.
07-22-2014 21:30
07-22-2014 21:30
07-23-2014 09:22
07-23-2014 09:22
EVERYONE SHOULD WATCH CEREAL KILLERS! It is the best piece of information and will shift your consciousness on how you perceive nutrition and carbs especially. Totski you hit the nail on the head so many times. We go to the gym and see so many people wasting their time with a workout that does not help them at all. I am sure you know about the H.I.T. intervala training which it appears is what you are doing. We have to re-set the metabolic clock and I loved what you wrote. Hopefully many people will read and heed your words!
08-12-2014 00:29
08-12-2014 00:29
Hello, without “being the expert” but been training for the last 30+ years military and civil, my “old boy” experience would suggest you are over training to some degree. If you would Google “aerobic and anabolic” and have a read up, it does cover the issues you are writing about I feel.
In essence when you go pass your burn state, your body enters survival mode and depending who you listen to, stops burning fat and uses muscle fuel for the balance of your workout as a safety mechanism!
I use the Polar website for the formula which is a heart rate of 220 minus your age = your maximum burn rate. 70% of this is your peak figure for burning fat no matter what you are doing, you just need a heart rate monitor or use your gym equipment to measure, most people over train! Fact…
Most of all enjoy and Intelligent training.
Best Regards
David
08-12-2014 09:15
08-12-2014 09:15
Best Answer08-13-2014 00:15 - edited 08-13-2014 00:17
Gluconeogenesis - is the conversion of amino acids (protein) to glucose for the body to use as fuel.
It is slow and inefficient.
It is the wall that recreational marathoners hit when they go out too fast, and it is very evident when it hits there at 3-4 hrs, because you are forced to slow WAY down, since the ratio of carbs for fuel is now so low because it's so slow, fat needs to become the predominate fuel source again, and that only happens at slower pace.
Even pro marathoners with 5% body fat have enough fat to do several marathons in a row. The carbs is the limiting factor. Well, and joint pounding if honest, though the documentary Running the Saraha proves otherwise.
That point ONLY happens when you run out of carbs in the muscles where they are needed.
You get a slightly earlier point where blood sugar drops because liver stores are getting low, this happens at 60-90 min depending on intensity, and the amount of glucose for blood sugar levels to be kept up isn't that great at all, but it can effect your thinking, even though your muscles have plenty of energy to go.
So no - your body doesn't start burning muscle as a survival mechanism during exercise - unless you are truly starving for weeks, and you ain't going to be exercising to any degree getting no food in.
I'll mention too that 220-age is very rough, very wide bell curve. More chance of being 10 bpm outside that figure than close to it.
And you actually keep burning fat right up to the anaerobic threshold, hence the name, without oxygen, which means total carb burn at that point.
The % of fat you burn keeps decreasing because the amount of calories in general keeps going up, but the actual grams of fat being burned remains about the same up to that point.
You are kind of referring to the myth of the fat-burning zone as best workout spot, with no consideration for the reason for the workout.
That is indeed best for recovery level workouts. Not best for burning the most calories and fat ultimately.
I'll agree lots of people do overtrain for their fitness level when they get gung-ho, but the body has a way to adapt.
They rarely get a good recovery from their workout, so they don't get stronger. So eventually they just have mediocre workout after mediocre workout, unable to push nearly as hard as they could, because they just have plain tired muscles. And while that is a stress on the body, it kind of prevents overtraining because they are just too tired to push hard correctly.
10-13-2014 12:20
10-13-2014 12:20
As a little insentive muscle is heavier than fat so thats why when you are trying to lose weight take your measurements chest, waist, hips, upper arm and thigh and see if you notice a change in measurements after each week. I am struggling to see any change in my weight also though I have lost an inch round my waist. Hope this helps. I am not giving up but understand how you feel.
10-13-2014 22:41
10-13-2014 22:41
@Larracroft wrote:As a little insentive muscle is heavier than fat so thats why when you are trying to lose weight take your measurements chest, waist, hips, upper arm and thigh and see if you notice a change in measurements after each week. I am struggling to see any change in my weight also though I have lost an inch round my waist. Hope this helps. I am not giving up but understand how you feel.
And since it takes a long time to build muscle, water even takes up less space when spread out, and first improvements body makes to exerise is to take on more water with more stored glycogen.
So while fat takes up more space and a 1 lb loss can be very evident with inches in 1 spot, water spread throughout the muscles being worked may never show up.
10-14-2014 00:33
10-14-2014 00:33
10-15-2014 04:55
10-15-2014 04:55
i neva did zumba but worked out hard , i found it helped alot to drink the 2ltres of water but thats just me , another thing remember sometimes your turning the fat to muscle so u think that your not getting any were but your tonning up , keep strong , go hard or go home. 🙂 good luck
Best Answer10-15-2014 06:48
10-15-2014 06:48
@tibtif91 wrote:another thing remember sometimes your turning the fat to muscle so u think that your not getting any were but your tonning up , keep strong , go hard or go home. 🙂 good luck
Just to correct a myth and misunderstanding.
You can NEVER turn fat in to muscle.
At the most you could hope to lose fat while gaining muscle (which is not the same as gaining strength, which you can do without gaining any muscle).
But that is a very SLOW process if strength training and existing muscle is already tapped out for strength, 1 lb gain muscle in 6-8 weeks if eating at maintenance, slower yet if eating in diet.
Sorry, but you can lose fat a whole lot easier than you can gain muscle.
10-15-2014 08:52
10-15-2014 08:52
Another myth to not fall for is that you can spot reduce (and therefore lose weight). I've had pesky soft fat around my abdomen even though I achieved my target weight. I'm just making sure I do enough walking and running and calisthenics to hopefully chip away at that fat. It's going to come off all over my body, though. Not just because I do a lot of side leg lifts, crunches, and situps.
10-16-2014 08:59
10-16-2014 08:59
I had a similar problem, and met with a nutritionist who told me that WHAT I was eating was the problem, because my calorie range was within guidelines. Since then I've changed up some of my food choices on her advice. Seems to help.
01-07-2015 11:27
01-07-2015 11:27
There is more than one aspect to exercise. I posted her a few times about not over restricting your calories that cause the body to go to 'starvation mode' and to loose excessive amounts of lean muscle. Another aspect is not that you exercise but how you exercise. There are two categories of exercise: Aerobic and Anaerobic.
Aerobic uses air, of course. This is your cardio type, get your heart and respiration up. There are two ways to do, high intensity and low intensity. Example of high intensity is interval training where you give it all you got for 2 minutes, then rest for 30 sec and go again all out for 2 mins. With this form, you'll exhaust your muscles, glucose levels, etc. You don't burn as much fat DURING the exercise, but fat burning will continue after you've stopped. Low intensity would be like walking or jogging at a slow steady pace over a long time period. This will burn a lot of fat WHILE DOING the work, but fat burns drops pretty quickly afterwards.
Anerobic includes things like resistance training and here again, intensity can vary. Heavy weights, few reps are high intensity and similarly, don't burn a lot of fat during the exercise, but continue to burn long after the exercise is over. Heavy weight lifting breaks down muscle tissue. That soreness is the result of lactic acid release and tiny tears in the muscle fibers, so after a hard workout, the body has to repair the damage you've done. As it does this, it attempts to prevent future damage by making the muscle stronger and this is how muscle tissue is built. The repair process takes energy too. You've also depleated all the glucose stores that were in your muscles so those have to be replished. ITs a lot of work, so you body augments with burning fat to aid in the process. Low intensity is light weight and lot of repetition. This tends to do less damage to muscle tissue, so most of the fat burn occurs during the exercise to replace energy being burned, but again, drops quickly after the exercise.
So which one is better? That depends on your goals, your time and even avaialbility of equipment. Alternating these activities can also have its effect through muscle confusion. Always changing up what and how you do things keeps your body from adapting. Back when I did a lot of running, I would run 4 miles 5 days a week and on the 6th I would do an LSD (Long Slow Distace) run of 8 miles at a much slower pace. As I am just trying to get back into shape now, I'm starting slow and just walking with two or 3 days a week devoted to heavy lifting. I will probably transition to more high intensity resistance on a more regular basis.
01-23-2015 05:48
01-23-2015 05:48
If you are working out that much, you probably arent eating enough....try increasing your protein too, or just take a day off from your workout, I bet you see a loss. Dont give up, you will find the formula to success
02-03-2015 19:50
02-03-2015 19:50
My best advice, and a tip I learned from a fellow fibit user, is to establish a small goal of 5 lbs, then once that is met add another 5 lbs and so on. It is so much more rewarding. Allow a breather day, and realize that it is possible to over do it.
02-05-2015 05:19
02-05-2015 05:19
Good morning.
Like many here, I am moving more, eating less, and working hard, but not seeing the number on the scale drop...YET! Seems like it's pretty common (unfortunately), but I know persistence will pay off. Besides, what negative can there be to eating healthier and exercising?
Finding it frustrating sometimes not to see the scale drop, I am always looking for others experiencing the same/similar for ideas/suggestions to shake it up a bit, and maybe even just to commiserate.
This morning, I read an article about a woman who successfully lost (and is keeping off!) 69 pounds. I found the article to be inspirational in a very realistic way.
She says, "There will be times that you won’t see the number on the scale. Take before pictures so you can see how far you’ve come! Also, take measurements because as you replace the lost weight with muscle your inch loss will decrease and may not show when you weigh in."
Lord knows I have enough "before" pictures to choose from. I have done the measurements a few times, and that does seem to help. Sounds easy enough, so I may just take her advice (in addition to the scale) as motivation!
Best of luck to us all!
02-21-2015 19:45
02-21-2015 19:45
Hi, I been walking for 1 year now. And on December 29 2014. I bought this fitbit zip and i love it.
yes trying to lose weight it's harder for me to do to lose weight for me.....
But I have lost inches on my legs..... and good luck
best of luck
Best Answer03-18-2015 12:51
03-18-2015 12:51
Best Answer08-28-2015 10:35
08-28-2015 10:35
I have been trying to lose weight for 3 weeks now and have only lost one pound. I got my Charge HR on August 7th. I walk at least 5 miles a day, use my Bowflex three times a week. Trying to run 1/4 mile during my walk and increase by a little each week. I set my deficit to 750 calories, but I only have 15 lbs that I want to lose. I have either honeynut cheerios with strawberries and almond milk or egg beaters with light string cheese and a high fiber/low fat tortilla for breakfast and coffee with creamer, usually 3 oz of rotissere chicken and green salad for lunch, no dressing and 3 oz of meat, green salad and veg for dinner. Snacks are usually fruit, wasa crispbread and hummus or string cheese. My calories intake is 1200 or less and calories burned 1850 -2050. I am getting frustrated and almost want to stop the exercise. In 2007 I joined Weight Watchers and lost 35 lbs in 6 months so why can't I lose now. I didn't do much exercise then, just counted my points, it was hard for me to stop losing and maintain then!! Five years later I was back to pre Weight Watchers weight probably because I started my old habits of chips, sour cream, ice cream, i.e. junk food.. I think I was a carb lover, so tried not eating bread, pasta, refined sugar, just eating protein, veggies and fruit. Anyway, now I am 66 and want to get to 130 lbs. Need help/motivation? I have been reading a lot of comments here and seems like everyone says it will eventually start to come off. Do you feel it is necessary to exercise everyday or is it okay to take one day off a week?? Just feeling discouraged I think. thanks for listening/reading.
Best Answer08-28-2015 11:31
08-28-2015 11:31
@tickfit1949 wrote:I have been trying to lose weight for 3 weeks now and have only lost one pound. I got my Charge HR on August 7th. I walk at least 5 miles a day, use my Bowflex three times a week. Trying to run 1/4 mile during my walk and increase by a little each week. I set my deficit to 750 calories, but I only have 15 lbs that I want to lose. I have either honeynut cheerios with strawberries and almond milk or egg beaters with light string cheese and a high fiber/low fat tortilla for breakfast and coffee with creamer, usually 3 oz of rotissere chicken and green salad for lunch, no dressing and 3 oz of meat, green salad and veg for dinner. Snacks are usually fruit, wasa crispbread and hummus or string cheese. My calories intake is 1200 or less and calories burned 1850 -2050. I am getting frustrated and almost want to stop the exercise. In 2007 I joined Weight Watchers and lost 35 lbs in 6 months so why can't I lose now. I didn't do much exercise then, just counted my points, it was hard for me to stop losing and maintain then!! Five years later I was back to pre Weight Watchers weight probably because I started my old habits of chips, sour cream, ice cream, i.e. junk food.. I think I was a carb lover, so tried not eating bread, pasta, refined sugar, just eating protein, veggies and fruit. Anyway, now I am 66 and want to get to 130 lbs. Need help/motivation? I have been reading a lot of comments here and seems like everyone says it will eventually start to come off. Do you feel it is necessary to exercise everyday or is it okay to take one day off a week?? Just feeling discouraged I think. thanks for listening/reading.
First, a 750 calorie deficit is too high if you only have 15 pounds to lose.
Second, 15 pounds isn't something to be stressing about. I'm sure it's a big deal to you, but honestly, in the big picture of life, I wouldn't be so worried about it. And the increased cortisol from stress is going to make losing weight even harder anyway.
From what I see, and I may be wrong, you're working your body hard and not feeding it enough. It's going to fight you on that. Your diet is very carb heavy, and carbs are not evil, but you need to work on adding more protein and fat too. You need more calories (set your calorie deficit at 250 and eat until it says "You nailed it"), fewer carbs, more protein and a little more good fat.
Have an avocado and an egg or two. Have a bigger piece of meat. Get good sleep and be happy.
