I am weighing myself every Monday morning and I am going to log my results each weigh for accountability and support. Please feel free to join in.
Start weigh 125.5 kg 14/12/2015
Now 124.2 kg 11/01/2015
Loss this week 200g
Loss to date 1.3kg
"Slow and steady wins the race"
I managed to overcome that plateau, made it to 193.7. I've had to really slow it down this last week. I kept getting shin splints in my left leg and I have a tender patch of skin under my knee that feels like I'm ripping off a bandaid anytime I stand up.
Congrats on the victory over your plateau @Jerson213!!! But sorry to hear about your joint pain!? 😯 Not sure how to best overcome that but wishing you a speedy recovery!
Without really planning it, I took a bit of a break from logging. I got the Aria scale and was trying to quit obsessing over weight and forcing a weigh in number. So, rather than focusing on one low number per week, I am allowing more data points and accepting that it will look like I have gained a few pounds when in reality I have not. It's more of an accuracy correction.
So, I am still holding steady in the low 160's. Thanks to Aria, I have a reference point for body fat as well. I am not sure how accurate it is but at least I can see variance. It's reporting me in the high 12's or low 13's for bf % which is pretty good I think.
Week 6/12 (half-way through!) of cutting phase during which I’am trying to lose between 0.25 and 0.50 kg per week in average:
Week 0, ending 4-Jun-18: 64.4 kg, 14.2k steps, 2819 cal.
Week 1, ending 11-Jun-18: 64.7 kg, 20.2k steps, 3162 cal. -> +0.29 kg
Week 2, ending 18-Jun-18: 63.6 kg, 21.8k steps, 3098 cal. -> -1.17 kg
Week 3, ending 25-Jun-18: 63.1 kg, 17.2k steps, 2952 cal. -> -0.47 kg
Week 4, ending 2-Jul-18: 62.6 kg, 23.4k steps, 3128 cal. -> -0.44 kg
Week 5, ending 9-Jul-18: 62.5 kg, 20.4k steps, 3032 cal. -> -0.16 kg
Week 6, ending 16-Jul-18: 62.0 kg, 25.6k steps, 3177 cal. -> -0.47 kg
I had a very good week, on point in terms of both activity and eating. I’m still in the middle of my self-assigned weight loss range:
This week should be easier, because my latest weight from this morning (60.8) is already where the average for the forthcoming week is supposed to be (according to the -0.5 kg per week plan):
Dominique | Finland
here is my weekly weigh-in: Start weight 265 lbs (8/1/2008) Now 206.4 lbs (7/16/2018) Goal 150 lbs. LOSS this week 2.4 # Loss to date 61 lbs Next Mini weight goal 195 lbs. Have a great week everyone !!
I am new to this thread but I have been keeping track of my weight since April 3rd when I started counting calories with the help of Fitbit. I weigh myself every morning so I look at the mean weight every week to see my progress.
This week was a good week calorie wise and weight wise since I didn't do that many social things.
Starting weight: 69,7 kg
Goal weight: 60 kg (I may change this later depending on what my body will look like.)
Weight loss this week (week 14): -0,9 kg, mean weight 62,9 kg
Previous weight loss/gain since April 3rd 2018:
-0.9 pounds this week for me, for a total loss of -36.3. Hopefully this week I can hit my short term goal of 234 before I head out for vacation next Wednesday and start a two week maintenance.
Date/Starting Weight/New Weight/Net
1-15-18/271/271/+0
1-22-18/271/269/-2
1-29-18/271/266/-5
2-02-18/271/265/-6 (pre-vaction)
2-11-18/271/271/+0 (post-vaction)
2-12-18/271/268/-3
2-13-18/271/267/-4
2-19-18/271/264/-7
2-26-18/271/263/-8
3-05-18/271/261/-10
3-12-18/271/259/-12
3-19-18/271/257/-14
3-26-18/271/255/-16
4-02-18/271/254/-17
4-09-18/271/252.6/-18.4
4-16-18/271/250.4/-20.6
4-23-18/271/249.7/-21.3
4-30-18/271/248.7/-22.3
5-07-18/271/246.9/-24.1
5-13-18/271/245.3/-25.7
5-21-18/271/244.2/-26.8
5-28-18/271/243.2/-27.8
6-04-18/271/242/-29
6-11-18/271/240.4/-30.6
6-18-18/271/238.9/-32.1
6-25-18/271/237.8/-33.2
7-02-18/271/237.2/-33.8
7-09-18/271/235.6/-35.4
7-16-18/271/234.7/36.3
Short Term Goal: 234
@HisDudeness: first of all, congrats for your slow and steady weight loss! You’ve been in weight loss mode for 26 weeks and lost 13% of your starting weight. I believe switching to maintenance for a while is a good idea, but 2 weeks may be too short. One set of recommendations I’ve seen that makes a lot of sense to me is the following:
Admittedly, this slows things down, if/when you’ve got a lot of weight to lose. OTOH, this should limit the risk of rebounding and make it less likely for the dreaded plateaus to occur. For the rationale behind that approach, see Losing All Your Weight At Once.
Dominique | Finland
I'm back on my workout routine! First day back and it felt so good. Leg no longer hurts, but I still feel this strange sensation, like when you take off a sticker from your skin. I don't feel it when I workout though, so that's progress, right? I weighed in today and I'm at 191.1 lbs. I'm 1.1 lbs away from reaching my goal of 190 lbs. Cheers to all of you that keep encouraging me to stay active, and to those that congratulate me on my accomplishments. You are very much appreciated!
@DominiqueThanks for the advice. I did do a short 2 week maintenance back in April. But still lost a bit due to the fact I set my Fitbit to -250 deficit and I was usually more than that. I am never quite sure of what is the real number calories burned for exercise. My exercise routine is going to the gym doing strength training 3 days a week. At first I could barely do 30mins a session, now I am going for 45-50 mins. I also go for a 2 mile walk at least 5 times a week. I don't do much cardio as I have read online, that if you are really overweight it can cause your body to hold calories.
But all that being said I perhaps I should do a bit longer maintenance phase. Would 6 weeks be sufficient in your opinion?
@HisDudeness wrote:perhaps I should do a bit longer maintenance phase. Would 6 weeks be sufficient in your opinion?
The idea of a maintenance phase / diet break is to offset the impact on metabolism of dieting down to a lower weight. It needs to be in relation to the dieting phase (duration, amount of weight loss): you have been dieting for about 6 months (minus the two-week break) and have lost 13% of your starting weight. Based on that, the maintenance phase should be longer rather than shorter IMO. 6 weeks is definitely better than 2 weeks. Whether it’s "sufficient" remains to be seen. The longer you spend at your new, lower weight, the more likely that weight is going to become a new "settling point" and you will be in a better position to start your next weight loss phase.
Dominique | Finland
July 22
Goal is 155 lbs
Down 0.6 lbs this week to 163.7 lbs. The snapshot of body fat % as I crossed 164 lbs shows me at the same percentage as when I reached that weight in July 2017.
Ave. Fitbit-calculated daily calorie deficit last week
-0.6 lbs since last week, -3.6 lbs since June 10.
Goal Range: 155-165 lbs
| Cut | Bulk | Cut | ||||
| Weight (lbs) | Date | Body Fat % | Date | Body Fat % | Date | Body Fat % |
| 168 | 6/25/17 | 19.9 | 4/30/18 | 20 | 6/1/18 | 19.7 |
| 167 | 7/5/17 | 19.5 | 4/14/18 | 19.4 | 6/18/18 | 19.3 |
| 166 | 7/12/17 | 19.3 | 4/1/18 | 19.1 | 6/28/18 | 18.9 |
| 165 | 7/19/17 | 19 | 3/19/18 | 18.9 | 7/11/18 | 18.9 |
| 164 | 7/22/17 | 18.8 | 2/26/18 | 18.6 | 7/19/18 | 18.8 |
Scott | Baltimore MD
CW: [ 330 ] -334-334-333-336-336-334-332-334-330-332-337-337-340-336-333-331-326-333
- 4 lbs
Week 7/12 of cutting phase during which I’am trying to lose between 0.25 and 0.50 kg per week in average:
Week 7, ending 23-Jul-18: 61.0 kg, 17.8k steps, 2852 cal. -> -1.04 kg
Although it looks like I lost 1 kg during the past week, I was in fact at maintenance, as I had already reached the weight goal for this week last Monday (I’m reporting weekly averages for weight). Now again close to the more aggressive boundary of my self-assigned weight loss range:
Nothing special coming this week, so hopefully I’ll be able to drop further weight.
Dominique | Finland
July 23
SW 78k
CW 65.8k
GW 60k
My weight this past week hovered around 66k. Yesterday I took a day off from exercise, walking, etc (only 3,500 steps I think); so I was pleased my weight was back in the 65.+k range. Goal: reach 65.0 by month’s end.
I am currently at 158.6 pounds. It took me over a year and a half to lose over 40 pounds with my fitbit. I have about 4 pounds to go to reach my goal of 155.
@Bionicwoman71 wrote:I am currently at 158.6 pounds. It took me over a year and a half to lose over 40 pounds with my fitbit. I have about 4 pounds to go to reach my goal of 155.
Hi @Bionicwoman71. As my friend @SunsetRunner said in another post, slow and steady wins the race.
Looking at some of your other posts it sounds like your approach is mostly habit and "fix your environment by getting crap out of the house" based and your slow pace is on purpose. I think that kind of approach has the best chance of long-term success. By not going into big calorie deficits you are less likely to be hungry all the time and not constantly testing your will power. That gives you a chance to try various small changes that add up to weighing less the rest of your life instead of the roller coaster that seems to occur when the approach to losing weight has nothing to do with the approach to maintaining lost weight.
@Bionicwoman71: I think you’ve already reached your goal! Shouldn’t your goal be a range within which it’s OK to fluctuate, rather than a single number?
Dominique | Finland
Hello Dominique. My ultimate goal is to reach a morning weight (or before I eat or drink anything) of 155 pounds. I will fluctuate up to 161 during the day and that's fine. 5-6 pounds fluctuation is okay. I am a little over 5 foot 8 inches almost 5 ft 9. I want to look good but not skinny for sure. So I lift weights, do zumba, hip hop abs other aerobic dvds and walking. I think size 10/12 dress size which is where I am is good enough.
