My Fibit One has suddenly begun to lose battery power rapidly. It lasts maybe a couple of days on a full charge.
Today when I plugged it in to charge, I checked it after five minutes and it had gone from empty to full. I can't believe that that is correct.
I noticed that the Fitbit App updated on 28/4/17 and am now wondering if the battery drain is real or is being 'misreported' by the app. This would seem to tie in with the sudden change of battery status I have experinced. Prior to this it would run quite happily for 7-10 days before I recharged it (well before it reached critical status).
Has anyone else had similar issues?
06-13-2018
14:04
09:32
06-13-2018
14:04
09:32
@pdagrl Welcome to the Fitbit family! Thanks for reporting the situation you are experiencing with One draining its battery quickly.
It's been a long time since you have your tracker! It could be that the battery is not working as good as when it was new. However, please feel free to check these tips to maximize its battery power.
Hope this helps. Keep me posted! ![]()
Best AnswerSoon after my 6/18 post, the One would no longer charge at all. Fortunately, I purchased a new unit some time ago as a backup, so will enjoy it as long as it lasts.
Best AnswerMy One has started experiencing rapid battery drain. This is my second tracker in three years; the first one died for no reason and now this one won't go for more than five days without suddenly going to low battery and then zero within 12 hours. (Prior to that, I could get at least a day or two out of a low battery before it went to empty; now it completely shuts down once the battery dies and I have to reset it.)
14:29
09:32
10-08-2018
14:29
09:32
@Lebe @outatime Welcome to the Fitbit forums! Thanks for taking the time to report the situation you are experiencing on this thread. Thanks for providing all the details regarding this.
I went ahead and created a case with customer support in your behalf for further assistance. Please keep an eye on your email inbox for next steps.
@Aquae I hope you're doing well! Thank you very much for providing your help and experience on this thread. I'm sure this will help other users too. Thanks!
@pdagrl Thanks for your reply! I'm glad to read you had a new One unit. I'm sure it will last a lot of time for you. Let me know if you need any help with it.
