10-14-2017 13:09 - edited 03-21-2018 10:28
I've been notified that there are reports of One battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Actively managing your weight? Find accountability buddies on the Manage Weight board
01-16-2018 12:53
01-16-2018 12:53
Fitbit is never going to fix this, they're just waiting for all of us to age out. They keep telling the new people the happy story of "working on a solution," while most of us sit here for months unable to keep a charge longer than 3-4 days.
I'll keep limping along with the One until I get too annoyed, and then I'm through. Fitbit gets no more from me. Terribly disappointed in them.
01-18-2018
20:31
08:40
SantiR
01-18-2018
20:31
08:40
SantiR
My One had been having charging issues since the most recent update and has now gone blank...not holding a charge at all. Mine is older, though...just celebrated its 4th birthday last month.
Moderator Edit: Format
01-19-2018 06:16
01-19-2018 06:16
Mine is old also. I have told them they should allow one users to roll back until they can fix issue.
01-29-2018 00:44
01-29-2018 00:44
My Fitbit Battery is full charge but not working
01-29-2018 02:48
01-29-2018 02:48
This is exactly the issue I have.
They have just sent me a second replacement One.
The first replacement behaved in exactly the same way as my faulty One.
Fingers crossed that this second replacement works - but I have little hope of this being the case, as they have not indicated any reason why the first two failed.
While it's generous of them to send me not one, but now two, replacements; if the issue is unresolved they are simply sending me non-working products.
In the meantime (mine has been unworkable since early Jan) I have purchased a Misfit Shine 2.
I'm not as enamoured with it as I was with my One - but it is working smoothly, which at the moment is gold!!
01-29-2018 04:30
01-29-2018 04:30
That's great! Congrats!
01-29-2018 07:28
01-29-2018 07:28
Since December 13, after the update and changes made, my ONE is still staying charged 15 days. Hopefully continues.
01-29-2018 10:18
01-29-2018 10:18
@suefit5 I guess you are speaking about the One device firmware upgrade (not just the IOS app update)? Very interesting to get such positive report: thanks! If there are some more, I may tempt the upgrade but I resist at this stage
01-29-2018 10:34
01-29-2018 10:34
02-27-2018 19:32
02-27-2018 19:32
Its now Feb 2018 and the One is still draining in <48 hours. Seems a fix would have occurred by now!
Any update?
02-27-2018 19:40
02-27-2018 19:40
02-27-2018 23:44
02-27-2018 23:44
02-28-2018 07:56
02-28-2018 07:56
02-28-2018 10:46
02-28-2018 10:46
Mine does finally last longer on a charge, yet I cannot turn on syncing, which was one of the reasons I use a Fitbit. Still profoundly annoying.
02-28-2018 11:14
02-28-2018 11:14
02-28-2018 19:02
02-28-2018 19:02
24 hours ago I fully charged mine, then did a reset. I just looked at it and its in the red already! I am using version 64 according to the app. I don't see a way to update the version. Is this the latest? All day sync should not do this. I just turned off items like the water, etc that I don't use. Will see if that helps.
03-01-2018 07:50
03-01-2018 07:50
03-03-2018 10:06
03-03-2018 10:06
03-03-2018 15:03
03-03-2018 15:03
03-04-2018
07:11
08:47
SantiR
03-04-2018
07:11
08:47
SantiR
Yep I'm also done with Fitbit. They don't seem to want to take care of their customers. I won't buy any of the ones that they pushing now... I'm done!
